Chemical injection cleaner
04-13-2012, 12:12 PM | #1 |
1435
Rep 4,724
Anyone ever had this done. Dealer is saying my hesitation in 6th gear is probably from intakes. I've heard of the walnut blasting on here, but not the chemical one. Dealer is doing it for free due to my prior fuel system problems.
On another note: I just had an N55 loaner while getting tires and alignment, and it felt much quicker at lower speeds. Maybe my intakes need cleaned that bad. I have 69k miles on my car.
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
04-13-2012, 12:15 PM | #2 |
302
Rep 4,444
My SA also just said they do not offer the Walnut blasting (and said he called around and no other local bay area dealers do either).
He was surprised because he agreed that with DI the chemical process is pretty much BS and the walnut shell is the way to go. |
04-13-2012, 12:22 PM | #3 |
1435
Rep 4,724
Hmm. I'm getting it for free, so might as well try.
04-13-2012, 01:03 PM | #4 |
38
Rep 1,079
If you are referring to a chemical treatment to clean your injectors, then perhaps it might be worth it. Don't expect your intake valves to magically get cleaned though. (Direct Injection)
2004 E46 M3 | Imola Red on Cinnamon | Slicktop | Manual Seats | 6spd MT |
04-13-2012, 01:06 PM | #5 |
88
Rep 1,404
The popular of the "chemical" intake cleaning system is offered by BG Products. Around the country, there are BG service stations who offer this service. It's inexpensive than stealership prices, but quality of cleaning is not as thorough as chemical hand cleaning or walnut shell cleaning.
http://www.bgfindashop.com/bgservices/fuelair.htm FYI, for mitigation and reduction maintenance of valve deposits, I do alternate between, Chevron's Techron cleaner, BG's 44k and MOA products Grant- You may want check with ABS - Alternative BMW Service in San Mateo and ask for John. they have a strong reputation. From my understanding, they clean the valves by hand.
Name: Blanca | 07 E92 | AW-Blk | ZSP | Alcon BBK | M3 Bits | VM RR Links | Koni | UUC Sways | V5 | Dinan CAI | ETS IC | Fge DV | ER CP | Cyba | Raden. Exh | Mod Step | Trunk Drawer | Perf LED Wheel | Illum Dr Sills | IS Shifter | Parrot | Philps D1S | 6000k fog | MTECH RR | CSL Trunk | Aero | Roof Spoiler | PSS on BBS RS-GT 19s
04-13-2012, 01:36 PM | #6 |
1435
Rep 4,724
The SA said the used to just run AT fluid through them years ago before this new thing.
04-13-2012, 02:39 PM | #8 |
388
Rep 1,945
The dealer down near me says they only walnut shell blast mini coopers and chemical clean was for our cars. they said if they found any walnut shells they would void warranty or something..?
04-13-2012, 11:09 PM | #9 |
1435
Rep 4,724
I'll post results after next week to see if it worked. Thanks all.
