What fuel?!
04-10-2012, 06:43 AM | #2 |
19
Rep 344
Drives: 911 C2S & '118D
I only use V power as it seems to be the best fuel the UK has for turbo'd car. Had to fill up once with standard fuel and the power loss was instantly noticeable. Seemed to get less MPG as well but not sure it was all down to low octane fuel.
04-10-2012, 06:50 AM | #3 |
886
Rep 9,097
V power or bp fuel.
For me Bp always worked better in terms of mpg but v power is better for acceleration. Honest john has mentioned on many bmw reviews that these cars are require premium fuels.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
04-10-2012, 07:22 AM | #5 |
118
Rep 3,866
04-10-2012, 08:04 AM | #6 |
32
Rep 1,271
Drives: 335i (sadly gone)
I allways use V-Power. Apart from this weekend when I drove all round Essex to find every Shell garage sold out and had to get Momentum. Bit of a waste of the V-Power I had left really.
04-10-2012, 08:48 AM | #7 |
35
Rep 914
Shell seem to be the most competitive on price at the moment in london!
Yesterday the only garage with standard fuel for 139.9 I usually go with Tesco Momentum for the clubcard points though! Eases the paid of paying 146 or whatever it is now. |
04-10-2012, 09:01 AM | #8 |
67
Rep 1,273
I was planning on using V Power but there isn't many Shells locally to me and often have to drive out of my way to get it. However, I have a feeling it will be worth it....
Failing that I'll give Momentum a go! Thanks |
04-10-2012, 09:09 AM | #9 |
32
Rep 1,271
I've had no problems and I think Momentum is pretty good for the 335i. As said the clubcard points are a bonus but I would still go out of my way to get V-Power and also use the drivers club card!
04-10-2012, 04:24 PM | #10 |
LSD - No, you're not seeing things
72
Rep 3,302
The Subaru ran like a dog on BP, and only ran smooth on Shell.
The 335i runs okay on cheap Shell, but better output and I calculated 8% more mpg on VPower. So, the extra cost of premium is negated - in effect you get a free performace upgrade.
04-11-2012, 06:24 AM | #11 |
1545
Rep 8,972
Evolve tuning did some back to back dyno runs on a standard 335i with normal ron95 and v power. The v power produced 40bhp more! Perhaps momentum too, but it wasn't around then.
04-11-2012, 06:31 AM | #12 |
Capt Slow
37
Rep 1,076
I've honestly never taken much notice of 'premium' fuels thinking they were just an expensive rip off. Might try a tank of shell or bp and see how I go.
04-11-2012, 06:47 AM | #13 |
67
Rep 1,273
04-11-2012, 06:48 AM | #14 |
Rep 313
I've always used VPower - I was panicking a bit when it ran out within an hour's radius of me during the recent panic buying but the cheap stuff was in stock so looked into BP and Tesco more.
I found quite a few bad stories about BP Ultimate which surprised me, I was always under the impression it was good but experiences and test results suggest otherwise so for me it's VPower all the way and if I ever need to, plan any route via a Tesco 99 |
04-11-2012, 06:52 AM | #15 |
41
Rep 683
V-Power
2010 E90 335i M-Sport, 2005 E90 325i M-Sport, 2003 E60 520i, 2002 E46 330i Sport II, 2000 E46 325i Sport I, 1999 E46 318i, 1998 E46 323i SE, 1996 E36 323i SE, 1996 E34 518i, 1995 E36 320iA, 1994 E36 316i
04-11-2012, 07:00 AM | #16 |
Rep 103
I've found that with my 335i and Jb4, Tesco momentum is the best out of all the premium fuels. With V power I normally hit 14/15 psi on auto-tuning map 5, but with momentum99 I get 16/16.5psi. It's certainly a change that can be felt put it that way
04-11-2012, 07:53 AM | #17 |
16
Rep 529
I seem to remember reading that Tesco Momentum contains the dreaded ethanol (fuel pump killer, allegedly)? In which case I'll stick with V Power.
Does Tesco Momentum contain ethanol? Mike. |
04-11-2012, 07:59 AM | #18 |
32
Rep 1,271
Don't know if it helps but I used to have a turbo'd RX8 and only ever put V-Power in it. I moved and thought that bP ultimate would be OK and I was wrong. I never tried Momentum (or any standard fuel) but running on anything but V-Power it would knock badly.
At one point I got caught short so put in an octane booster (as allways) and BP Ultimate thinking that this has got to be OK and it got to the point of detonation in every sense of the word I needed a new engine! Surprisingly I don't get BP fuel anymore. |
04-11-2012, 09:06 AM | #20 |
Newbie
Rep 13
Ok I don't have a shell local to me the nearest is between 50-80 miles away so what fuel to people recommend?
I have tesco's, sainsburys morrisons bp and esso around me which should i use? |
04-11-2012, 09:14 AM | #21 |
41
Rep 683
BP Ultimate and buy V-Power when you can.
04-11-2012, 10:58 AM | #22 |
Rep 463
I did not believe this when I first got my car a year ago. Thought I would try V Power just to see and yes : more MPG and a smoother ride. Other premium fuels no difference to normal stuff.
