Dual-exhaust conversion on PE
04-09-2012, 01:01 PM | #1 |
40
Rep 544
Drives: BMW 435i xDrive M-Sport
Hey guys, after buying the BMW PE for my 328xi, I'm now very interested in converting the tips into duals (335i style).
I will be buying the M-tech bumper and the 335i Duke Dynamics dual diffuser (the one with the middle fins). I want to cut out the tips on my 328i BMW Performance exhaust, add an extension pipe to the right side and install new tips (or the PE ones but seperated). Would it affect the noise or the car's performance? I don't want to ruin my exhaust because I put a lot of money into it! If anyone knows, is this feasible? I've already seen it on this forum (the one with the Montego blue color), but not on a BMW PE... That's where I'm concerned. Thanks! |
04-09-2012, 01:26 PM | #2 |
I got lei'd
844
Rep 7,593
What was that guys forum name? I was thinking about drilling a hole in my eisenmann muffler but I might just drill a hole at the mid pipe.
So half muffler, half muffler delete, if you don't want to ruin your PE. And look underneath we don't have much space, it'll be a very thin pipe, not enough sound from there. |
04-09-2012, 03:17 PM | #3 |
40
Rep 544
Here you go: http://www.e90post.com/forums/showthread.php?t=557918
This is EXACTLY what I want to do... Can I do it with my BMW PE? |
04-09-2012, 04:14 PM | #4 |
92
Rep 1,456
Dont think it will work. The way the PE sits in there is the same way the OEM muffler does. It takes up all of that space so I dont think youll be able to route the pipe tight enought to be able to get it to the other side. Plus there is a hanger there that will get in the way.
It will be alot of labor, if the space is even there to do it. |
04-09-2012, 04:21 PM | #5 | |
40
Rep 544
04-09-2012, 04:35 PM | #6 |
92
Rep 1,456
I mean it may have to be like a 90 degree turn right out of the right outlet on the pe muffler, but then I dont know where you will be able to snake it thru to the other side. It will be very restrictive like that and most exhaust will want to flow out of the drivers side tip. Do you have the PE yet or are getting it? It takes up the whole area there so It will be some seriously tight bends and just noit sure if clearance will be there.
04-09-2012, 04:48 PM | #7 | |
40
Rep 544
Check out the link thread I posted with the Montego Blue 328i : http://www.e90post.com/forums/showthread.php?t=557918 I was thinking of welding a perpendicular pipe to the actual pre-tips on the PE all the way to the right side and weld a tip on there... As you said, most of the air would get out of the left side but who cares, it can't be perfect... I'm worried if it will affect the noise or performance of the new exhaust... Last edited by Gjm127; 04-09-2012 at 05:06 PM.. |
04-09-2012, 05:32 PM | #8 | |
92
Rep 1,456
Do it! Just make clean cute on the tips you have, twist up the piping and just do it. If it doesn't work you can always just toss the stock tips back on. I dont think anyone has done it but i think it would be nice.
I have a muffler delete and love it. Would love to do this, and It would be super easy for me, but would need the bumper, etc. Quote:
04-09-2012, 10:02 PM | #9 |
40
Rep 544
So should I tell the mechanic? After cutting the tips, how is he going to close the left hole? And where does he drill the second hole to weld the extension?
I really need reassurance that I'm not affecting the (awesome) noise of my PE!!! |
04-10-2012, 12:29 AM | #10 |
77
Rep 2,114
Gavin has some experience with slicing open the suitcase style muffler like a sub sandwich, maybe he can toss his .02 in for how the secondary pipe should exit the case.
E92 '08 335Xi 6AT - Cobb AP3 Tuned by MAC Autosport, Original Prototype Xi DOCRace 6266 Single Turbo Swap, VRSF CP w/Synapse BOV, VRSF 7" FMIC, BMS Cowl, H&R Coilovers, Renn Motorsport RS-51's, Stoptech Stage 2 Slotted, xHP Stage 3, Earl's Racing Oil Cooler, Turner Boost Gauge, M3 Lip Spoiler.
Standing Mile Record Holder for Xi over a mile high: 168.2MPH @ 5512'; The Colorado Mile hosted by The US Mile. |
04-10-2012, 12:35 AM | #11 |
Where'd my VTEC go?
481
Rep 6,067
It's not going to work. There is no room for the piping with the PE muffler. Plus you would have to re-route BOTH tips not just one because the 335i exhaust cutouts are a lot more inset than the 328i.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
04-10-2012, 10:11 AM | #12 |
40
Rep 544
I drew a possible configuration for my custom exhaust but it would need some serious delicate work.
Here's how it goes: I would need to cut both tips to the neck. Weld a 90° pipe that covers BOTH holes and weld an extention pipe to the right side. Then drill the two holes at the right places and add tips. On another note, if the mechanics tell me they can't do it, how bad would it be if I just put a fake tip on the right side? I do drive in cold weather lol... |
04-10-2012, 12:56 PM | #13 |
Kumar
71
Rep 747
Hey man I'm looking to do a similar conversion but I want to do a quad conversion with my PE.
I took it to a local muffler shop and the guy said that it can be done, but it will take some $$$. I'm thinking about first getting rid of that storage compartment in the trunk and replacing it with a shallower compartment so I have more space for piping. Similarly I'll be doing a restricted 90 degree angle right off of where I get the tips cut. I'll be getting under my car today to plan it but I'll keep posted. |
04-10-2012, 04:11 PM | #14 | |
40
Rep 544
It's great that we both have the same idea (custom duals/quads on PE). We're going to try to work out something to make everything fit just fine. Keep updated! |
04-10-2012, 06:05 PM | #15 | ||
Semper Fi
23
Rep 417
Drives: E60 ///M5
04-11-2012, 05:28 PM | #16 |
40
Rep 544
Yesssss.. I'm getting it done next week!
I'll draw a sketch of what the technician told me he was gonna do. There is a lot of place btw. Basically it's gonna take 40 minutes and cost 150$. I'm seriously worried about the legitimacy of this exhaust place cuz the price seems too cheap to me lol... Am I doing the wrong thing? |
04-11-2012, 05:37 PM | #17 | |
92
Rep 1,456
That is an incredibly low price for the work involved. Depends on pipe material (stainless vs raw steel), Quality of welds, quality of bends (mandrel) All depends.
Seems very low of a price, but if it is done well and all that then it is a sick deal. Post bunch of photos and stuff. Quote:
04-11-2012, 05:48 PM | #19 |
267
Rep 1,203
40 min is WAY under estimated IMO, their will be alot of bending, test fitting...making things work..It took alittle over 2 1/2 for me to get my 335i exhaust welded onto my car..including custom mounts, fabrication. I had the same ideal but everywhere I went to didn't want involved or found the job to complex for their shop
04-11-2012, 08:56 PM | #21 |
Kumar
71
Rep 747
Damn man you are flying through this! Lol.
I called like 3 muffler shops and they all said they didn't want to get involved. However one of them is interested. What bumper and diffuser are you getting? I wanted to just get my oem bumper cut and get quad Cyba tips when I get the piping done. Idk if I should do that anymore tho, lol. |
04-11-2012, 09:13 PM | #22 | |
40
Rep 544
Well the place I went, they're Dominicans that only do exhaust jobs. I went to several legit places and they all refused to do the job because they simply don't want to get involved with Bimmers... Don't mind the 40 minutes, it could take longer... Does the 150-200$ sound legit? lol.... |
