COBB Stage 2 Agressive
04-07-2012, 08:09 PM | #1 |
85
Rep 1,356
Finally got my VRSF DP's installed today. First off great fitment and good pipes for the price.
Now on to the second problem. I have COBB Stage 2 Aggressive installed on the car and it just feels like its sluggish in the first gear. I am on V301. I felt that when I was no Stage 1, it was more responding from the get go but now it just feels like the first gear its struggling. Is that normal or just map's are wrong? I always thought aggressive are the maps that give the most "push" in the seat. Also seems like car is running a little hotter, around 240, is that normal? Lastly, do I need to do anything for the DP fix or anything with the COBB UPDATE: These are the error codes that I am throwing after driving car and service engine soon light is on. P2C2B, P29E1, P2C24 Last edited by Motastic; 04-08-2012 at 04:50 AM.. |
04-07-2012, 08:12 PM | #2 |
70
Rep 2,197
To answer any of your questions about performance with any accuracy we need to see logs to be sure everything is working as it should.
As far as the DP fix: are you talking about passing emissions or just getting rid of the CEL. |
04-07-2012, 09:08 PM | #5 |
178
Rep 11,768
i'm a procede guy ( gee i wonder if its because SO many people have issues with the bmw cobb) i am almost certain its because you are on v301, horror. but i think i can help you out as i use one in my STI. have you tried the beta v4.01 maps? it was supposed to be fix the issues some members got with underboosting,
you can log right through the unit itself, goto monitor, and second option data log. can also set whichever parameters you want to log- RPM Boost TPS PWM/DC Ignition IAT Fuel/AFR basically, boost, target boost, timing advance, AFR, and RPM, usually are suffice . do some 3rd gear pulls from 2k.. iirc, on cobb logs on e9x you will see and want to log RPM WGDC ALL CYL (1-6) IAT LOAD Act lOAD req boost afr 1/2 throttle(tps) timing export the saved csv file and we can take a look.. here's a noteworthy read, it will help you out. http://www.cobbtuning.com/v/vspfiles...FinalAlpha.pdf
-Rev
SGM e92 335xi|Helix|AFE|AWE|PROCEDE|SYNAPSE|ER|OSS|BMW PERFORMANCE|P3|always growing.. Last edited by RevC; 04-07-2012 at 09:29 PM.. |
04-07-2012, 10:00 PM | #6 |
70
Rep 2,197
If you just wan't to get rid of the check engine light then all you have to do is run stage 2 or stage 2+.
As far as logging: Select what channels you want to log. I do RPM, throttle position, timing cyl 1-6(you PROcede guys don't know nothing bout that), charge air temp, lambda 1&2, WGDC, load req&act, and boost. Then find a safe, empty stretch of highway and do either a 2-3 gear pull or 3-4 gear. I do 2-3 because of safety reasons. Select monitor->datalog and start logging right before you go WOT. Then hook up the AP to your PC and export the files. Use excel or virtual dyno to graph the logs and post em to get some reviews. Ohh, and I've got nearly 20K miles of trouble free EXCELLENT performance from Cobb. |
04-07-2012, 11:08 PM | #7 | |
208
Rep 2,558
2. Use v401 maps 3. Make sure you're using stock throttle maps, not linear (it seems you would prefer ST maps) 4. 240F I believe is fine. The car is making more power, so you'll have more heat. It shouldn't go above 250F 5. Cobb will suppress the codes for your cattless DP's. However, if you want to pass emissions, you will need the BMS DP Fix to pass readiness.
'07 Space Gray 335i coupe - R.I.P.
COBB ProTuned | AMS | CP-e | BMS | Quaife |
04-08-2012, 04:51 AM | #8 |
85
Rep 1,356
Well after driving the car around for a while, i plugged in the cobb and got the following codes P2C2B, P29E1, P2C24
also i realized its not so much the cobb but it seems like the car when first turn it on, it sputters or hesitates, feels like after a few seconds, is about to turn off. Same as far as pwoer goes seems like it really has to build up before it goes do the codes have something to do with it? |
04-08-2012, 05:03 AM | #9 | |
70
Rep 2,626
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar.
'05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT COBB, FBO, st2 LPFP, Mfactory LSD | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
04-08-2012, 08:22 AM | #10 | ||
169
Rep 1,247
2009 E92 BMW M3.
04-08-2012, 10:22 AM | #11 | |
15
Rep 457
Rev, I am trying to send you a PM. Your inbox is full. Looking for some information that I thought you may be able to help with me.
2008 E92 335i M-Sport | Sapphire Black | Sunroof | Creme Beige | Poplar Grey | Logic 7 | 6AT | 19" AG M359's | Michelin PS4S | LUX V3 | MHD V5 E40 | Steve AZ Walbro inline | Vishnu DCI | BMS CP | AR Design Catless DP's | Forge DV's | Helix IC | (Stock Cat. back) |
04-08-2012, 10:26 AM | #12 |
70
Rep 2,197
04-08-2012, 10:32 AM | #13 |
169
Rep 1,247
thank you for the explanation. Just curious as to I am thinking about getting VRSF DPs so I cant use the COBB stage 2+FMIC. Just dont want to deal with emissions issues in PA which are a pain. But the extra bit of power and sound from DPs would be nice.
2009 E92 BMW M3.
04-08-2012, 10:46 AM | #14 |
70
Rep 2,197
Stage 2+FMIC is a VERY fun map. It would probably be worth swapping the DPs out once a year for inspection(if it's visual) or getting the BMS DP fix if it's just OBD2 readiness.
04-08-2012, 11:48 AM | #15 |
30
Rep 474
You did something wrong with the O2 placement. Fix your mechanical mistake(s).
If you're hesitant about emissions on catless downpipes, Stg1+ makes identical power and torque to 5krmp. The Stg2+ maps really don't take advantage of the flow in their current form, I'm still patiently waiting for a protuner to take their skirt off and protune an FBO car.
//ecg//
04-08-2012, 01:09 PM | #16 | |
70
Rep 2,626
04-08-2012, 02:28 PM | #18 |
70
Rep 2,626
if that is your problem which I think it is, yes everything should be back to normal
04-08-2012, 09:23 PM | #20 |
130
Rep 5,040
04-08-2012, 09:26 PM | #21 |
70
Rep 2,626
COBB doesn't when your car is in good shape and when you're running non-beta maps. Plus COBB does not have an auto clear function.
I've been running problem free for the past 25k.
04-08-2012, 09:33 PM | #22 |
208
Rep 2,558
LOL... so wrong on so many levels...
