Project: Internal Upgrade - Rainbow SL100 Coaxial (center)
04-07-2012, 02:29 PM | #1 |
281
Rep 4,121
Edit: COMPLETE!!!
Guys, As you've seen I am running the Rainbow SL100 as my center, which I like because:
Unfortunately the SL100 has a 20w (min) - 30w (max) recommended RMS power range...which has limited my ability to run more power to it, to balance my front stage. Since I am planning a big power upgrade to my system...this had to be fixed.... Idea! The Cal20 tweeter is allegedly the tweeter portion of this coaxial. Rainbow lists the cal20 as 100w tweeter! So what's holding back the power rating?!?! I suspect it is the limitation of having only a 6dB/octave crossover. I had thought of biamping the center in the past to get more distortion free headroom for the same wattage...this is what got me thinking...If I am going to wire the mid and tweet separately, why not just delete the crossover internals? Last edited by taibanl; 04-27-2012 at 04:47 PM.. |
04-07-2012, 02:41 PM | #2 |
281
Rep 4,121
As you can see...the center of the coax includes the concealed crossover components. They are (in series):
I also tested the voice coils. The tweeter is 8ohm while the mid is 4 ohm...this was a surprise to me as the CAL20 tweeter when purchased as a component is a 4ohm tweeter...not sure if this affects my plans at all. The question is...what should I replace them with? I plan on crossing the coaxial outboard of the speaker (either active w/ MS-8 or passive), but I want to retain some tweeter protection. Choices:
The included PTC fuse was .65 amp. I bought a .75 amp, 1.1 amp and 1.3 amp PTC at parts express...I plan on using one of these..just not sure which. Since I am planning on a steeper cross than 12dB/octave I think its fine to go to a higher trip rating. The capacitor options are either 10uF or 22uF as per the above link. 22uF gives me ~900hz Hi-pass, 10uF gives me ~2khz Hi-pass. (keep in mind I will run a dedicated crossover BEFORE the speaker....this is ONLY for protection...not for an effective crossover freq.) What would you pick and why? |
04-27-2012, 04:59 PM | #3 |
281
Rep 4,121
Finally COMPLETE!
I ended up replacing the tweeter altogether with the 4 ohm version which I ordered from rainbow. I had to steal the mounting core off of the 8 ohm one, which was glued on pretty seriously. I also purchased an extra crossover that matches my front L+R and is biampable. Very excited to get this hooked up. |
04-28-2012, 07:03 AM | #5 | |
281
Rep 4,121
