Adjust 'Clutch Point' for Procede NLS?
04-06-2012, 09:16 PM | #1 |
Black on Black on Black.
38
Rep 532
I have an ACT Street HD Clutch/Pressure Plate, as you know the shift engagement point is significantly 'lower' than stock. The NLS system doesn't work smoothly because clutch 100% engagement occurs -before- the procede thinks it does, it's very difficult to drive with this on my shifts are much faster and accurate without it.
Is there any way to adjust this level so I can use NLS? Does anyone else have the same problem? |
04-06-2012, 09:20 PM | #2 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
I haven't looked at the switch mechanism in the footwell. But I wouldn't be surprised if it could be adjusted. Give it a look and see if the switch is mounted on a threaded rod. If so, adjust it as you see fit.
04-06-2012, 09:35 PM | #3 |
38
Rep 532
Hey Shiv,
Thanks for the heads up, can you give me any info on the signal / how the procede works? Is it on/off or a range indicating position? Is there an 'adjustable variable' somewhere in the map? I'll look into the switch, but I'm almost entirely sure its position is non-adjustable. |
04-06-2012, 09:37 PM | #4 | |
1737
Rep 17,960
Drives: A Lot
