FBO 335i blowing smoke need help!!
04-06-2012, 01:50 PM | #1 |
47
Rep 483
Not too familiar with this car yet n I'm no
Mechanic but I can install parts. Installed Ar design Downpipes and a helix intercooler the other day. I have jb4 been running map 1 for about 3 months. With intakes, vanguard exhaust n eta charge pipe n bov. Switched jb to map 2 for dps mAp. Drove for a day n started hitting light packs if boost. When I took it hard in 4th ( automatic s mode) it cut off n went into limp mode. ( intercooler cupplers came off :/ car has been giving a burning oil smell n Grey white smoke when accelerating hard n when stopping car is engulfed in smoke. I checked all the cupplers everything is super tight now. Car is out of limp mode n boosts fine. Still throwing smoke n burning oil smell. Can anybody chime in on what might be wrong?? |
04-06-2012, 01:54 PM | #3 |
Rep 153
samething is goin on with mine, sorry to say its most likely Ur turbo seal failed and is dripping oil onto Ur exhaust.causing it to smoke. u can check my posts I got Ur same concerns.
AR~~~Injen~~~BMS~~~~Hks~~~~ETS~~~~~Mtech~~~~~Helix ~~~~~Bimmian~~~~Vorsteiner~~~~~WeissLicht~~~~
04-06-2012, 01:57 PM | #4 |
25
Rep 294
Blown turbos or blown head gasket.
2012 X5 35D - Platinum Gray / Cinnamon Options: Sport, Tech, Cold Weather, comfort seats, leather dash, high beam assist, lane-departure warning, soft-close doors, two-row, self-leveling suspension, hi-fi stereo
Tracks driven (in any car): Nürburgring Nordschleife (05/2011), LeMans (ok, just the public part), Eagles Canyon Raceway, MotorSport Ranch Cresson, COTA Austin |
04-06-2012, 02:03 PM | #5 |
156
Rep 3,730
Going catless will reveal problems that were covered up by the stock cats. Most likey you have a blown turbo seal. Is the smoke only coming out of 1 exhaust pipe? (Not sure if Vanguard has a H pipe).
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
04-06-2012, 02:41 PM | #7 |
481
Rep 4,155
Drives: 1/18 Monte Carlo Blue E92 M3
Black smoke = bad. White smoke = ok.
04-07-2012, 08:21 AM | #10 |
125
Rep 1,546
This seems to be as common as fuel pump failures.. turbo seal most likely.. The white smoke (oil burning) is coming out of your exhaust, so that means its something internally, not oil leaking on the exhaust as someone has mentioned.
Gonna have to more then likely bring it to the dealer, after you have returned it 100% back to stock. They will probably just replace the turbo.. Sad to see how common this is! |
04-07-2012, 08:49 AM | #11 |
14
Rep 290
Do you have a oil catch can.
2008 135i 6-speed current stock for now
1995 e36 M3 5-speed Jb4 G5//CM-FX400//FBO//Meth// 12.06@118 6-speed manual sold summer 2013 |
04-07-2012, 10:52 AM | #12 |
47
Rep 483
Returning back to stock I don't c as an option as they will clearly c it was modified.. Oil catch can is what ltbme suggested as well. If a turbo seal is crapped out or both seals r crapped out will the car still boost fine n run fine?? I have a 500 mike trip I need to go on. If I don't hit boost will the car be ok for it
04-07-2012, 02:59 PM | #15 |
14
Rep 290
I had this issue a month ago purchased the bms oil catch can.. Haven't has an issue with smoke since I have 75k miles on stock twins as well
04-08-2012, 11:22 AM | #17 |
47
Rep 483
anybody elses input?
so far ima try the following things oil catch can if no fix take to a shop or bmw for a diagnosis. possible turbo seals spark plugs, oil lines vaccum lines |
04-17-2012, 11:00 PM | #19 |
Rep 54
If your cat less this could be hydrocarbons burning up in the exhaust rather than in the cats where it is turned into NOx which helps the cats operate the way they should, also if there is no cats then there is no where for this conversion to happen there for the exhaust just burns off the HC's and not convert to NOx and H2O. Blue smoke is oil, white sweet smelling smoke is coolant plain and simple. Ask any master tech and they will probably tell you the same thing. Any thing else is dependent on the modifications to the exhaust.
04-24-2012, 12:03 AM | #20 |
36
Rep 1,019
Ok, I'm pretty sure I figured this problem out. I've been having the same problem. As the car downshifts (AT) to a dead stop there seems to be a cloud of smoke right? Well, I changed my CP for a ER one with my HKS I had laying around. I noticed that there was a good amount of oil in the OEM tube, not A LOT but enough.
Same goes for the front mount when I changed it out last week. So now I know that it is oil being sucked up and just being burned because the smoke doesn't appear all the time. So with that said and done, I'm sure a OCC is going to fix this problem like vereak82 said. So I guess I know a future mod LOL, hope this helps you guys
@ichi_ban
06-25-2012, 05:53 PM | #21 | |
El Jefe
39
Rep 1,345
If this helps, I have installed: Meth JB4 FMIC ER CP ER Synapse BOV AA DP Vanguard Exhaust BMS Oil Catch Can |
