engine problems e92 330i 08
04-06-2012, 05:19 AM | #1 |
Rep 62
When you decelerace on the 2nd, 3rd, 4th and let the rews to go down to apr. 1300rpm and than give full gas, the engine starts to flutter and than the engine control appears.. it does happend from time to time.... when you turn the engine off and start again, it is all sound.. in higher (above 2.000) rews is everithing all right.
Any idea what it could be? 67.000km 08, Germany version Thanks |
04-27-2012, 12:57 PM | #2 | |
Rep 83
04-27-2012, 01:37 PM | #3 |
Freight Dawg
104
Rep 2,103
Sounds like a bad coil to me. Have the car scanned for misfire codes. (I'm assuming that's why your check engine light is on.) Swap the coils on the cylinder with a misfire with one that is not misfiring. If misfire follows the coil then you know it's a bad coil.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors |
