Engine cover sits too high
04-05-2012, 01:51 PM | #1 |
Rep 175
Is there a way to adjust the engine cover so it sits lower? I had my cylinder head replaced last year and now I have to push down on the cover to open the oil cap.
04-05-2012, 02:28 PM | #2 |
92
Rep 1,456
Take it off by pulling up, bend the metal tabs with the rubber grommets that hold it onto the engine. Put back on.
04-05-2012, 02:46 PM | #3 | |
303
Rep 2,485
Drives: 340Xi MG 2017
they're out) but if you just pull, your valve cover will most likely break.
04-05-2012, 02:55 PM | #4 |
92
Rep 1,456
04-05-2012, 05:14 PM | #6 | |
Rep 175
Really? I have to turn the screws when I take it off of my 330. Maybe it has something to do with production date because we all have 06's
04-05-2012, 05:30 PM | #7 |
92
Rep 1,456
You're referring to the silver plastic engine cover? The scres on mine are more of a rivet and have nothing to do with the underlying metal bracket with rubber grommets.
Im an early 06 330i. US |
04-05-2012, 05:40 PM | #8 |
Rep 175
I am referring to the silver plastic engine cover. I have huge torx screws on mine that require a half turn to pop off. I believe it locks the cover between the rubber grommet and the metal bracket. I have a 5/06 330i also US.
04-05-2012, 06:14 PM | #9 |
92
Rep 1,456
Now that I think about it I think I do have those screws, but have literally never turned them. I have always just pulled up and out with the whole cover. But to solve the original issue, I would say take it off either way, and bend the brack so it sits lower to the engine.
04-05-2012, 07:54 PM | #10 |
16
Rep 299
I have the same silver valve cover the screws
just hold the plastic cover to the rubber mounted frame. You do not have to touch them. Just pull up on cover. |
