04-04-2012, 03:47 PM | #1 |
Rep 10
2013 X3 N20 build available...sort of.
It shows the new options to build the 2013 X3 but not the engine specifics.
Still shows the I6 and not the N20. |
04-04-2012, 03:58 PM | #2 |
Lucky13
212
Rep 1,762
On the build page it shows the 6 but go under specifications and it shows the N20. Interesting that it shows the exact same gas mileage, 19 city and 25 hwy.
1995 325i, 1996 328ci, 1997 528i, 1997 Z3 2.8, 2000 528i, 2001 X5 3.0, 2001 330i Convertible, 2002 M3 Convertible, 2003 M3 Coupe, 2004 M3 Coupe, 2004 Z4 3.0, 2004 X3 3.0, 2007 X3 3.0, 2007 335i Convertible, 2013 X1 28 sdrive, 2014 M235 manual, 2020 X3 30i Xdrive
04-04-2012, 04:58 PM | #3 |
Unregistered
14
Rep 177
Noticed under the Dynamic Handling Package ($1400) it doesn't show Dynamic Damper Control anymore as it did in 2012.
It only shows: •Variable sport steering •Performance Control |
04-04-2012, 05:26 PM | #4 | |
*Bimmerpost Plasti Dip Guru*
83
Rep 1,174
Drives: E53, E46-M3, E70, F25-X3
04-04-2012, 05:52 PM | #5 |
Rep 34
I ordered a 2013 x3 35i with the dynamic handling package. When I check production status on the BMW website, it only shows Variable Sport Steering and Performance Control underneath the DHP, as you stated above. But it also shows Dynamic Damper Control as a seperate option. With the updated Build Your Own tool, dynamic damper control is listed under "Options", but it gets automatically selected if you select DHP under "Packages". You can't select Dynamic damper control alone, and there is no additional cost if you select it with DHP. I don't know why they changed it like this.
04-04-2012, 09:28 PM | #7 | |
Unregistered
14
Rep 177
When you do select it it makes you add the Dynamic Handling Package..does that make sense what they did..no...but then that website isn't the best. |
04-04-2012, 10:58 PM | #9 |
Unregistered
14
Rep 177
Yes it does according to the bmwusa.com site...add Dynamic Handling Package to the build and look in the upper right and you will see Dynamic Damper Control $0 added where it totals up the prices. It's different to the 35i which actually shows Dynamic Damper Control under the options tab. Screwy..yes
What I think is important for people to know, which I just realized, is the ZCW (Cold Weather) and the Driver Assistance Package can't be added together. |
04-05-2012, 12:47 AM | #10 |
126
Rep 1,781
