ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > General BMW Z4 Forum
  TireRack
      06-15-2007, 09:31 AM   #1
Waldorf
Black Opps field agent
Waldorf's Avatar
35
Drives: 135i M
2nd gear grinding
has anyone had a case of chronic grinding in 2nd?
when i test drove an M Roadster i got the 2nd to grind a few times unexpectedly. I'm a very experienced track driver, i don't grind gears. I thought that maybe the poor little M Roadster demo had been abused by a bunch of idiots.
now i've had my M Coupe for about two weeks and 1900 Km and got the grinding 2nd four times. WTH?
anyone?
:rocks: Montreal to Vermont OktoberFast cruise. :rocks:
http://www.e90post.com/forums/showthread.php?t=79557
      06-15-2007, 09:43 AM   #2
fire-n-ice
20
Drives: 2003 Z4
Waldorf, check your PM box...
      06-15-2007, 10:08 AM   #3
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
65
Drives: 2006 Z4MC Interlagos
anyone?
Its because the clutch takeup is so close to the floor - you need to be very percise in the M cars on the timing of the hand and foot work between 1 & 2. Its just not intuitive imo. The long clutch travel and short throw shifter seems to throw timing off too... You're not alone.
2006 Z4MC - #LL93158
SS Race Cans, RE X Pipe, DKF Sec 1, Fabspeed Headers, OE STB, AS Shifter, Dave Z CDV, GC Coil Overs, Stoptech lines, Hawk DTC Pads, RE Clutch Stop, RE Transmission Mounts, Vibra-Technics Engine Mounts, Poly FCAB & RTAB, LeatherZ M Shift Boot, Tekarbon Rear Spoiler, CF Grills, Advan RS DGM
      06-15-2007, 10:12 AM   #4
Rick Hunter
Skull Squadron Leader
Rick Hunter's Avatar
304
Drives: '07 M Coupé & '16 435xi GCoupé
X2. The first time sounded devastating!
      06-15-2007, 10:38 AM   #5
Waldorf
Waldorf's Avatar
35
Drives: 135i M
alright, thanks for the info. it's almost time for lunch so i'll try it soon.
      06-15-2007, 10:44 AM   #6
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
167
Drives: 2007 M Coupe
Yeah...2nd is the most challenging to get into.
07 ///M Coupe (Premium Package) Black Saphire Ext. Imola Red Int.
Best Website EVER!
      06-15-2007, 10:52 AM   #7
pbdm4k
pbdm4k's Avatar
74
Drives: 2010 335d
I'm just gonna be a prick and say its the driver, not the car.
      06-15-2007, 01:00 PM   #8
Godspeed
Drives: E85 3.0
It's not just the M's, it took me a while to figure out the 1>2 in the Zed.
The key is to shift like you do on a bike; pre-load the shift lever while still applying power in 1st and then allow the clutch disengagement to allow the shift. If power is still on, you can put a good deal of rearward pressure on the lever without it coming out of 1st. This results in a quicker, smoother shift without the risk of having the pedal coming off the floor while the lever is still travelling. Unless I'm just poking around town, I now pre-load all of my shifts.
      06-15-2007, 03:44 PM   #9
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
65
What would you know with your automatic
      06-15-2007, 03:47 PM   #10
enfield
Civilian
enfield's Avatar
79
Drives: Jaguar F-Type V8 S
I did it a few times too - in the beginning. I Coupe has never had that happen since I practiced on the first one
      06-15-2007, 03:57 PM   #11
pbdm4k
pbdm4k's Avatar
74
Drives: 2010 335d
Who said mine is an automatic? 6spd manual, thank you.
      06-15-2007, 04:24 PM   #12
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
167
It's true tho...if your accelerating fast and your body is being thrown backward and you're trying to kick the clutch while you're also trying to shift quickly it can be a difficult proposition. You know what they say...practice makes perfect.
Best Website EVER!
      06-15-2007, 05:59 PM   #13
freeman
Drives: 06 M roadster
anyone?
Yea,it happened to me a couple of times when i first got my car.
1)You can try to sit closer to the steering wheel and firewall.
2)Get a clutch stop to shorten the travel of clutch.
3)It is less likely to happen again when you got some miles on the car(after you get familiar with you car) .
The transmission will also "loose up" a little bit after some good track days
My car is super smooth right now compared to when it is new.
      06-15-2007, 06:41 PM   #14
Godspeed
Drives: E85 3.0
I don't think the clutch stop would help - it doesn't change the engagement point. If anything, it might make it worse if it inhibits full disengagement of the clutch...
Do M's have the CDV thingy? I removed mine on the 3.0i and it made a world of difference.
      06-15-2007, 06:59 PM   #15
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
167
Yeah...we have the CDV thingy
Best Website EVER!
      06-15-2007, 07:06 PM   #16
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
167
What I don't get is if this thing is so bad...what's the reason for putting it in there...
http://www.zeckhausen.com/CDV.htm
Best Website EVER!
      06-15-2007, 09:11 PM   #17
inTgr8r
inTgr8r's Avatar
2426
Drives: M2 Comp
I don't really have any problem with 2nd...
I have the CDV deleted... but don't see what that has to do with gear engagement.
It wasn't any different before CDV delete, other than the box was still breaking in.
2nd is a little tougher to engage when downshifting....
but a shorter gear is always harder to engage.
I def don't get any grinding...
Occasionally, I'll get a little *snik* if my timing is a little off.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold)
'13 E92 M3 Santorini Blue (sold)
'07 Z4 M Coupe Alpine White (sold)
      06-15-2007, 09:32 PM   #18
freeman
I forgot mention that i had the CDV removed too.That helps a little bit,but not much.
However,I think my gear changing is much smoother after some track days.
It might be the car or me getting better with rev match and H/T.
      06-16-2007, 09:24 AM   #19
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
167
Make sure you don't forget to give it a lil RPMs in your downshift. I've got no worries there. Every now and then during hard acceleration it can be a challenge tho...gotta keep that clutch in!
Best Website EVER!
      06-17-2007, 12:36 AM   #20
em2b96p
15
Drives: cbr600rr
i just got my z4 3.0 and i get a loud thud sometimes when i shift into 2nd..
also it seems 1st gear is really short and i need to shift inot 2nd really soon..
      06-17-2007, 07:26 AM   #21
155MPH
155MPH's Avatar
61
Drives: E89 Z4 sDrive28i M Performance
I agree with InTgr8r
      06-17-2007, 08:59 AM   #22
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
167
1st gears usually are...when I'm in traffic or not in the mood to accelrate hard...i usually just use 1st to get goin and do most of the accelerating in 2nd.
Best Website EVER!
zpost
