turbo lag?
06-14-2007, 05:46 PM | #1 |
Rep 163
turbo lag?
hmm...have a 335i as a loaner today.. have a 6 speed e46 m3 in the shop. love the car, but it appears that once you smash the pedal, there is a 2-3 second delay before you feel anything. its horribly annoying to say the least. i tried to switch lanes to accelerate ahead of an oncoming car, the car just stood there long enough to almost cause an accident. it then finally jetted forward. is this typical? is there a way to get around this....aargh. never driven a turbo before and if this is the norm, i never will again.
06-14-2007, 05:48 PM | #2 |
Rep 184
Is the 335 an auto? As far as turbo lag- there pretty much isn't any. You just may have been in the wrong gear and the transmission took a second to find the right one.
If all the animals below the equator were capable of flattery, then Thanksgiving and Halloween would fall on the same day.
06-14-2007, 05:51 PM | #3 |
76
Rep 1,292
I have test driven two 335i and felt none of the turbo lag you describe. One of the tests was an auto, and it had no lag.
What you may be seeing is a slight delay before the AT downshifts. Put the AT in sport mode and it will downshift much more readily. Try it out. |
06-14-2007, 05:57 PM | #5 |
Samtaro!
124
Rep 2,601
With the automatic, from a standstill, there is definitely a big lag. From a dead stop, if I mash the pedal to the metal, it does feel like 2 seconds before real acceleration begins.
Also, if you're just in "D" drive mode, it does take a little time for the transmission to kick down to a lower gear for acceleration. So I like to drive in "DS" mode to keep the engine in the power band for instant acceleration. The flipper shifter is good, but through corners, they're useless... |
06-14-2007, 05:59 PM | #6 |
95
Rep 2,573
Drives: AW DCT M3
6MT is the way to go...
06-14-2007, 06:02 PM | #7 |
61
Rep 938
Must be an Auto...if it is you gotta use the manual mode and just downshift like you would any other stick. Never have lag unless I use the full auto mode or forget to downshift.
06-14-2007, 06:34 PM | #8 |
101
Rep 2,317
No lag in my 6MT at all! That includes on the track where lag would be felt BIG TIME and be REALLY scarry! I am really impressed with the turbos!
06-14-2007, 06:45 PM | #9 |
41
Rep 3,200
In what sense? If you mean that it shifts faster, then no, it doesn't. If you mean it has less turbo lag then again, it doesn't. If however you mean that you always know what it's doing and the shifts always happen on time and when you expect them then :rocks:
328xi Coupe, Montego Blue on Black with Alum, Step, Sport, Premium, CA, PDC, Cold Weather (Damn Pennsylvania winters)
Current Mods: Heavy right foot - Planned Mods: Lightweight right foot |
06-14-2007, 09:08 PM | #10 |
184
Rep 1,702
Drives: Audi TTRS, 335is
The throttle response of the E46 M3 is exceptional with its individual throttle bodies. Coming from the M3, most other vehicles seem to have less responsive throttle. Having said that, it doesn't mean that the M3 is quicker, just that it has a very responsive throttle in comparison.
06-14-2007, 09:34 PM | #11 |
Moderator
132
Rep 6,775
Drives: TiAg E92 335
2-3 second delay?!? Coming from a turbo s2k, my 335 doesn't seem as responsive, but it has almost zero lag and instant torque whenever I need it to pass someone with no delay. I have a 6MT so I can't comment if your car was an auto that you test drove, but unless you were in the wrong gear i've never experienced anything like that before. Like all turbo cars, if its 90 degrees out and your engine is heat soaked, then driving off easy from a stand still then the car will have some noticeable lag, but that's about it really.
-Michael.
Berlina Black S2000 CR is now in the garage l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l |
06-14-2007, 09:46 PM | #12 |
12
Rep 294
all turbos have lag. there is a lag with the 335, but it isn't much in the world of turbos. 2 - 3 seconds is a bit of an exaggeration
06-14-2007, 10:56 PM | #14 |
born to be turbocharged
24
Rep 1,347
well, it could be a 6MT on 6th gear cruising on 1000rpm. than I believe that w/o changing gears it took like 2-3s to get to 1500rpm where U get the juice...
pls don't kill this thread argumenting why is the MT better like the AT and vice versa, it's so tiresome and boring reading all the same crap all the times... rather gather some info from the OP and find the solution |
06-15-2007, 12:49 AM | #15 |
95
Rep 2,573
Drives: AW DCT M3
Your 3rd reference sounds good.... I just felt like chimin in
06-16-2007, 06:40 PM | #17 |
Rep 46
Drives: 06 330xi
although i know this isnt a 335i vs m3 debate.........heads up i ran an e46 m3 from a light 2 days ago....the m3 had me 1st n 2nd gear.......and 3rd it was all mine...i took him by a car and half
06-16-2007, 06:45 PM | #18 | |
The Law.
301
Rep 14,283
Unless you have some insane mods or m3 cant drive, i call bs. |
06-16-2007, 06:55 PM | #19 |
Rep 46
Drives: 06 330xi
i had an 06 330xi but recently traded in for a 335i sedan....and the m3 driver is a friend of mine so maybe i can get some recorded videos up for yall'
