Shiv, please share with us what you think about a better IC for the 335i
06-14-2007, 12:59 PM | #1 |
Moderator
270
Rep 4,481
Hi Shiv
I have the PROcede ( v1.45 steptronic ) and I am very happy about your product. As everything each piece of the 335i is a compromise between price and functionality. I like to upgrade the 335i's intercooler. The reason is to keep the temp's low and to de-stress the turbos. How would a proceded car behave after such an upgrade ( bolt on, well sized and optimized for the 335i from a reputable company ) without a map supporting it ? Would you be willing, if required, to develop a map for IC upgraded PROcede customers ? I think about a SPEARCO upgrade. BTW, will you offer an IC upgrade for the 335i ? Thank you for feedback. Cheers Eugen |
06-14-2007, 01:29 PM | #2 |
96
Rep 2,587
Eugen, use scan software to check the IAT temps. I'm showing around a 30 degree increase under 10psi on mine. I'm not sure an intercooler upgrade is needed, but will hold back until I see the results of turbonetics IC.
06-14-2007, 01:44 PM | #3 |
Moderator
270
Rep 4,481
Terry,
Thank you for feedback. I already did my homework related to IC's and will be fine with lower temps and even zero power increase ( would be unusual ). Just want to avoid power loss and a confirmation of Vishnu. BTW and honestly, the PROcede is a great product. Engine smoother than stock, power everywhere. You will end up on it . Cheers Eugen |
06-14-2007, 01:50 PM | #4 |
35
Rep 1,084
Give it a month or 2 and folks here will be installing IC's with their Procede / AA XEDE / RD XEDE equiped cars and we will see if any software update is even required...
06-14-2007, 01:57 PM | #5 | |
96
Rep 2,587
If heat soak is a concern for you, I might suggest an IC sprayer. They are pretty cheap and very effective. Even a larger IC will heat up and become less efficent after a few laps.
06-14-2007, 02:10 PM | #7 |
Moderator
270
Rep 4,481
The engine temps did not increase with the PROcede. In general, the engine runs more on the hotter side. Nothing wrong to cool it down. Water spray is no option, I dont want to get a water tank.
06-14-2007, 02:14 PM | #8 | |
96
Rep 2,587
For the water tank use the wiper fluid, it has a warning when you're low, and holds around 1 gallon. The IC spray should just turn on at higher boost levels to cool the IC down a bit. Much safer than water injection, with a lot of the benefit. |
06-14-2007, 02:17 PM | #9 | |
OG
77
Rep 930
06-14-2007, 02:17 PM | #10 | |
Moderator
270
Rep 4,481
06-14-2007, 02:20 PM | #11 |
296
Rep 1,515
Drives: Ever changing fleet
Yes he is, engine temp is dictated by the coolant t-stat and radiator which are not used anywhere near full capacity under normal conditions. An aftermarket IC that lowers IATs 20 deg will not have any appreciate effect on coolant temp regardless if the ECU can add a deg or two of timing, UNLESS it takes up more surface area and blocks flow through the radiator enough that it cannot cool to capacity.
23 iX M60, 24 GT3 RS Weissach, 22 Rivian R1T, 23 RS3, 13 E92 M3 Competition: Akra Evo, KW V3, etc
06-14-2007, 02:25 PM | #14 |
Moderator
270
Rep 4,481
06-14-2007, 02:32 PM | #17 | |
96
Rep 2,587
06-14-2007, 02:36 PM | #18 |
296
Rep 1,515
You are on the right track, but keep on reading. Lower IATs that allow for more timing will lower EGTs. HOWEVER adding a deg or two of timing (which being generous a 20-30 deg reduction in temps will allow) will have little effect on lowering EGTs in any dramatic way. Finally, whats ~40 deg C less temp when the turbine is being bathed in 900+ deg C exhaust anyway?
06-14-2007, 02:50 PM | #19 |
52
Rep 1,714
I can't see what Terry writes (blocked!) but I have noticed that Terry is all over any thread that has anything to do with Shiv/PROcede
Kinda reminds me of this stalker I had to deal with a few years ago. |
06-14-2007, 03:16 PM | #20 |
18
Rep 88
Ok first of all there is NO need for an intercooler sprayer on a front mount intercooler set up. The front mounts do not heat soak like a top mount intercooler does. In the wrx world, this is why alot of people get the front mount intercoolers, to avoid heat soak and handle the bigger turbos, with more boost.
Chris |
06-14-2007, 03:47 PM | #21 |
96
Rep 2,587
We're just talking about IC's, nothing to do with procede or Shiv.
06-14-2007, 03:53 PM | #22 | |
274
Rep 6,510
Post in a bigger font, I dont think he can hear you yet... |
