Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Setup Options
      04-01-2012, 01:19 AM   #1
harendre7201
harendre7201's Avatar
67
Drives: 2015 M3
2011 BMW 328i  [0.00]
Setup Options
The car needs new shoes so I am about to the pull the trigger on a set of 19" M3 competition rims matte black from **********s for my E90.
The car has a H&R Sport Suspension springs
Rims:
Front: 19 x 8.5 ET35
Rear: 19 x 9.5 ET 35
http://www.**********s.com/M3-Compet...atte-Black.htm
Just running through the probable tire configs:
1. Front: 225/35/19
Rear: 245/35/19
2. Front: 235/35/19
Rear: 255/35/19
3. Front: 235/35/19
Rear: 265/35/19
Please give me advice of the the best possible options.
Lets be honest I am on a budget and dont need $400 tires.
I live in SoCal so just thinking about running summer performance tires.
Harry I.
Los Angeles
2011 AW 328i
2015 AW F80 M3
      04-01-2012, 01:21 AM   #2
325iii
WAHHH
18
Drives: 2006 325I Sparkling Graphite
i have
19 x 8.5 235/35/19 front
19 x 9.5 265/30/19 rear
Edit: I'm also in socal, the setup seems fine to me
      04-01-2012, 01:47 AM   #3
harendre7201
67
Drives: 2015 M3
what kind of tires are you running?
Harry I.
Los Angeles
2011 AW 328i
2015 AW F80 M3
      04-01-2012, 09:19 AM   #4
flip4335
General Nuisance in a Private Conveyance
flip4335's Avatar
77
Drives: like it's rented
Rims:
1. Front: 225/35/19
Rear: 245/35/19
2. Front: 235/35/19
Rear: 255/35/19
3. Front: 235/35/19
Rear: 265/35/19
You will speedo issues running the above configurations. Namely, the rear tire/wheel will be larger in diameter than the fronts. Those specs are only for the M3 due to the larger capacity in the rear wheel well and the M3 speedo was spec'd with larger tire sizes in the back.
Our non-M speedos were calibrated for a more consistent diameter front and back, so putting 30-series tires in the rear makes more sense in order to make front and back diameters consistent.
Best bet would be to run the following to ensure front and back wheel diameters are the same:
225/35/19F, 265/30/19R
or
235/35/19F, 275/30/19R
Both specs have less than one percent difference in diameter between front and rear. To validate, try using the wheel dimension calculator above this Tire Rack-sponsored forum to determine if your speedo will read correctly at 60 mph.
BMWCCA Member # 414198 |E90|SGM|6MT|Premium|Cold|Sport|Tint|LCI MSport Conversion|MTech|Blacklines|219M|PSS|Quaife|Helix FMIC|M3 Suspension|Megan Racing|GC Camber Plates/Coilovers|Eibach 440/800#|AR Catted DP|Cobb AP|StopTech Drilled/Slotted|SS Brake Lines|DWS
Quaife Review: http://www.e90post.com/forums/showthread.php?t=311570
      04-01-2012, 06:33 PM   #5
ModBargains.com
475
Drives: JB E92 335i
flip4335 is correct as you will throw off your speedo with the setups that you've mentioned. I would recommend that you go with either setups below.
Front: 235/35/19
Rear: 265/30/19 or 275/30/19
