TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Audio - Basic questions
      03-30-2012, 03:38 AM   #1
Ste133
Ste133's Avatar
21
Drives: 335i
Morning chaps,
I'm completely new to BMW audio so I apologise for the basic questions. I've tinkered around with cars in the past, but never with the BMW.
It's an e92 and I have the Pro iDrive (CCC - old version) with the basic speaker set up.
My questions are:
1- Can I add the under seat subs to my current set up? Will these need coding, or can I just wire them up?
2- If I was to change the door speakers, are these a straight swap or will they require coding too?
3 - Would you recommend an amp if I was to upgrade, or would the standard system be good enough?
There's plenty of information out there, but I'm a little confused with all the 'coding' requirements. So if someone could clear this up, it would be appreciated.
Thanks,
Steve
      03-30-2012, 04:19 AM   #2
creepy coupe
creepy coupe's Avatar
1867
Drives: BMW M340I G20
2015 BMW 435d  [0.00]
2009 335i  [0.00]
Coupe or saloon?
      03-30-2012, 04:33 AM   #3
Ste133
Ste133's Avatar
21
Drives: 335i
Originally Posted by creepy coupe View Post
Coupe or saloon?
Great question! It's a coupe! (I've edited my first post)
      03-30-2012, 04:47 AM   #4
creepy coupe
1867
2009 335i  [0.00]
I thought all Coupe's had subs under the front seats as standard.
      03-30-2012, 04:54 AM   #5
Ste133
Ste133's Avatar
21
Drives: 335i
I had a look a few weeks ago and I wasn't able to see any. However, maybe I need to take another look when I give her a clean this weekend.
      03-30-2012, 04:54 AM   #6
Bungle009
Drives: E92 M3
I think all cars have the under seat subs. You can add tweeters in the front doors very easily/cheaply.
The best VFM upgrade is the Alpine upgrade.
      03-30-2012, 05:00 AM   #7
Ste133
Ste133's Avatar
21
Drives: 335i
Thanks. If I was to upgrade to the alpine upgrade, is this a straight swap or do I need to get things coded in?
      03-30-2012, 05:28 AM   #8
deepsrd
deepsrd's Avatar
23
Drives: 440i LCI
Originally Posted by Ste133 View Post
Morning chaps,
My questions are:
Thanks,
Steve
I have the same setup as urs.. I have ordered my stuff and waiting to be delivered.
I am answering ur questions from what I know, and not what I have done (in due time)..
1. Your basic setup is waaay underpowered to add any aftermarket subs.. You will need an amp. (You should be having underseat 'woofers'. (they aint subs) ).
2. Door speakers are straight swaps. But watch out for mounting depths. you should be fine with anything under 42mm.
3. Go for a 4 or 6 channel amp. I went for the JL Audio xd600/6. Small amp which should fit in the OEM amp location (left side of trunk).
You do not need coding if you are just swapping the speakers or adding an amp (since yours is a base stereo setup). However, when adding an amp, it is strongly recommended to recode your HU to Hifi, which will hive a flat cleaner signal to your aftermarket amp. To avoid coding and still achieve a flat signal you can also use a DSP like the MS8.
Hope this helps.
Please also correct me if I am wrong..
      03-30-2012, 05:30 AM   #9
deepsrd
deepsrd's Avatar
23
Drives: 440i LCI
Alpine upgrade is a retrofit, and needs coding.
      03-30-2012, 06:13 AM   #10
Ste133
Ste133's Avatar
21
Drives: 335i
Hope this helps.
This is exactly what I was looking for. Thanks chap!!
      03-30-2012, 07:59 AM   #11
Statler
Major Pain in the Arse
Statler's Avatar
11
Drives: E92 320D M Sport
I believe that on pre-2010 cars it's straight upgrade with no coding required.
      03-30-2012, 08:08 AM   #12
deepsrd
deepsrd's Avatar
23
Drives: 440i LCI
My bad. That's true.. More info here..
http://www.1addicts.com/forums/showthread.php?t=505654
