Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > DSC failiure fixed for £130
      03-29-2012, 09:17 AM   #1
NormanHomes
11
Drives: 320D
Posted about this before but didnt get much response and couldnt find anything on it so thought few people might be interested
having had the lights on my dash all winter thought it was bout time i got them sorted
Had a mate scan the car for faults and it came up with the 5e20 code. did some research and found this - http://www.ebay.co.uk/itm/4002556788...84.m1439.l2649. offered 120 and got a counter offer of 130 so took that. arrived in post very quick -
Fitted it today earlier. Abs unit is easiliy accessible its just by the windscreen -
Whipped the old pump out, its held down by 3 10mm nuts and then the lines on top (takes some wriggling to get it past, i didnt remove anything else though). Abs unit out -
the whole units held together with 2x torx bolts
pump apart -
Slot new one in as it came apart
Whip it back in same way it came out
Thats bout it easy job took me just over half hour. Then just bled the brakes. Thought i was gonna have to take it to a mates garage to activate bleed mode but the brakes arent too bad. and more importantly, as soon as i started it up -
no more lights at last!!!
Gonna take it to a gravel car park later and activate the abs a few times and re bleed all the brakes tomo and should be perfect again.
There you have it DSC failure fixed for £130 (plus brake fluid)
      03-29-2012, 09:27 AM   #2
bmwak
bmwak's Avatar
106
Drives: 440i M-Sport Gran Coupe
Nice work. I heard a new pump is near enough £2k - definetely worth the effort. The DSC and DTC system are linked though so do test both out to ensure it works all good. Did you also code the unit to the car?
      03-29-2012, 10:02 AM   #3
makkan00
makkan00's Avatar
886
Drives: F83 and F36
I dont think you need to code it. All you did was changing hardware.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play
      03-29-2012, 10:10 AM   #4
bmwak
bmwak's Avatar
106
BMW definetely code it to the car for it to function properly. Don't know how the OP has done it.
      03-29-2012, 10:40 AM   #5
urfankhaliq
65
Drives: BMW 530e G30
You only need to code it if you replace the whole unit, this is just the mechanical side of it not the electronic so no coding required.
BMW 530e G30
      03-29-2012, 10:41 AM   #6
Giff
Giff's Avatar
Drives: E90
Fantastic work, no need to code, only replacing the block.
      03-29-2012, 12:07 PM   #7
NormanHomes
11
Drives: 320D
Yup no coding whatsoever didnt even need to clear the codes or put it into bleed mode. Just a couple of spanners, a bleed kit and some brake fluid. lights gone gonna re bleed the brakes now
      03-29-2012, 12:42 PM   #8
jimmylad
jimmylad's Avatar
England
44
Drives: e92 335d sapphire black
thanks for heads up
      03-29-2012, 03:09 PM   #9
makkan00
makkan00's Avatar
886
Drives: F83 and F36
Excellent write up.
      03-29-2012, 04:57 PM   #10
m1bjr
LSD - No, you're not seeing things
m1bjr's Avatar
72
Drives: Baby F36 Gran Coupe
You will still have error codes stored in the DME though.
Nice intel.
Were you the chap posted earlier this month about the BBA remanufactured idea and have now gone on and done it?
Steve
      03-29-2012, 06:33 PM   #11
NormanHomes
11
Drives: 320D
as long as i dont have the dash beeping at me everytime i start the car can always clear any codes next time i have a scanner to play with
and yeah that was me that posted about the units before. couldnt really gather any info on them so just went for it in the end and turned out very well. was worried about the ecu going nuts and throwing up a million faults for one reason or another but not problem at all
      03-30-2012, 09:44 AM   #12
rsmallwo
rsmallwo's Avatar
40
Drives: Z4 35i
sounds Great, good find
