03-29-2012, 07:06 AM | #1 |
12
Rep 315
Auto Hold - standard or option?
Hello
Can anyone tell me if the auto hold function is a standard feature when ordering an auto gear box (UK car)? No mention of it in the brochure (and can't see it on the option list unless i'm blind!) and loved it when I had a tester for the weekend. Thanks all.
F25 xDrive 20d M Sport in Alpine White, Pro Nav, Auto 'Box, 19" Wheels, Visibility Pack, Heated Seats, Reverse Cam w/ Top View, Sun Protection Glass, DAB radio
03-29-2012, 07:57 AM | #2 | |
18
Rep 252
03-29-2012, 09:21 AM | #3 |
57
Rep 554
Drives: 335D MSport 2016
It's standard and the good thing about it is it works with the stop start so you don't need to keep your foot on the brake.
It makes for lazy driving, auto release of the handbrake in the morning too, just press the throttle and go. |
03-30-2012, 08:34 AM | #4 |
Rep 125
Standard feature for auto trans. and especially handy if you occasionally leave the tarmac to steep hills and stuff. On the other hand it is one of the contributors to early wear of the rear brake pads if I am not mistaken.
03-30-2012, 09:04 AM | #5 |
72
Rep 876
Auto hold does not contribute to early rear brake wear. The rear wheels only lock when you are at a complete stop, thus no heat is generated, no pad material is lost etc...
03-30-2012, 09:14 AM | #6 |
Rep 125
I just forwarded what my service rep had commented on while replacing my rear pads the other week .
03-30-2012, 09:44 AM | #7 |
72
Rep 876
You'll hear all kinds of odd things from service reps, but I think you can think about it this way:
"If I park my car on the road for 10 years with the parking brake on and the car never moves, will my brakes be worn out after the 10 years?" Answer: No* the components may be rusty from non use but the pad material will be untouched. I think the biggest contributor to early rear brake pad wear is the brake force distribution. When you are just leisurely stopping the X3 is setup in such a way to drag the rear brakes in an attempt to prevent nose dive and keep the SUV flat and level. This is normal and to be expected. Now if you brake hard on the daily then your front brakes will get more use. |
03-30-2012, 11:17 AM | #8 |
Rep 125
It for sure makes sense when you think about it that way, but I still think that with this modern parking brakes which use brake pads instead of a cable in a conventional hand brake, there should be some wear at the component that mainly prevents the car from moving either when parking or auto hold on. I do not know at what level this wear would occur , but probably a lot less than other contributors like brake distribution as you mentioned or for instance ADB+X or the cruise control with brake function, or maybe even performance control when opted .
