How much camber can we squeeze out the front
03-29-2012, 12:15 AM | #1 |
734
Rep 4,635
I need to get an alignment tomorrow. Should I ask for max camber up front ? We can't get much but will that be any different? Also any recommendations on what settings I should get. Or just max camber up front and normal in the rear?
Follow my BMW instagram @CARMODIFICATION Let me know you are from bimmerpost and i'll follow back
03-29-2012, 12:28 AM | #2 |
164
Rep 2,556
Can't add neg camber up front w/o removing the alignment pins from the strut mounts. I'm not sure if you can unscrew the pins w/o removing the strut assembly from the car. If you can't unscrew them, you can drill them out. This will get you approx. -.5 d camber up front; not much but it will improve turn in and reduce understeer a bit. Def. worth it imo.
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
03-29-2012, 12:32 AM | #3 | |
734
Rep 4,635
03-29-2012, 12:37 AM | #4 |
164
Rep 2,556
I don't have a picture of it but you can find one in this forum. I unscrewed my pins when the strut mounts were out of the car. If it's a performance oriented alignment shop, I'm sure they can figure it out.
