Help engine "shaking" during startup ( put back my stock intake nd it happened)...
03-28-2012, 11:07 PM | #1 |
77
Rep 558
Drives: e90
Location: I'm easy. Put me in an interesting location with good people and I'm there.
I don't really know how to explain it other than it feels like when I first start up the car it feels as if the engine is shaking or so for 3 seconds where I can feel it when sitting down. It feels like it's moving left to right for a few seconds and just stops. I recently put back my stock intake and it started happening. Anybody know what could be wrong?
Help help plzzzz
#TeamstretchNpoke
03-28-2012, 11:15 PM | #2 |
101
Rep 2,095
Drives: 2019 Toyota Tacoma TRD OR 4x4
Not sure, but have you tried making sure you installed everything correctly and that there are no air leaks?
E90 325i|Sparkling Graphite Metallic|Steptronic|Black Leatherette/Dark Burl Interior|OEM Alarm|35%Front/5%Rear Tint|RD LED License Plate Lights|Rear Fogs Activated|Debadged|Smoked Sidemarkers|Blacklines|Depo P90v2|Matte Black Grille|BMS PBX|AFE Drop In|Charcoal Filter Delete|Air Scoops| RM Silicone Intake Hose| Magnaflow 14815| 19" Avant Garde M310|Continental DWS|M3 Lip Spoiler
03-28-2012, 11:23 PM | #3 |
77
Rep 558
Drives: e90
Yes im sure... i installed it rite
#TeamstretchNpoke
03-29-2012, 08:26 AM | #4 |
31
Rep 393
I was going to say that it might be an air leak after the MAF. Any unmetered air will throw the fuel calculation off and cause that issue. Even if you're sure you sealed everything up, I would go check again.
If that's not the case, you could try disconnecting the battery for several minutes to try to reset the car's parameters. |
03-29-2012, 08:28 AM | #5 |
290
Rep 28,154
check for vacuum leaks, you may have knocked a line off, or like the guy above said, you may have a bad connection after the maf, that causes hell for any maf car
03-29-2012, 11:24 AM | #6 |
77
Rep 558
Drives: e90
thanks alot..)
#TeamstretchNpoke
03-29-2012, 11:25 AM | #7 | |
77
Rep 558
Drives: e90
#TeamstretchNpoke
03-29-2012, 11:27 AM | #8 |
77
Rep 558
Drives: e90
problem solved thanks guys)i forgot to replace the new air filter... it was dirty. and it was an air leak LOL...T__T i forgot to tight the seal
#TeamstretchNpoke
