Universal Joint and Flex Joint!!! Clanking!!!
03-28-2012, 02:21 PM | #1 |
ArmyBMWSGT
Rep 8
Will someone please tell me the difference between these two, i go everywhere and i get different answers, some say its the same thing others say its two totally different things. Can someone please post pics of these or links to a site that can describe these in detail. I think these or this or whatever may be the problem with the clanking and slamming i hear coming from underneath in the drivetrain.!!! help please would like to know more before I take it into the stealer to get it fixed
Germany + Autobahn + My 328 = Perfect Testing Ground
03-28-2012, 07:24 PM | #2 | |
Rep 291
Drives: 2008 328i, with 3 pedals
A universal joint is a broad term used to describe a joint that allows two connected shafts to be non co-linear. This may be why you hear some people describing the flex coupler as a universal joint. A classic U-joint consists of two yokes that allow a wide range of misalignment (bent shaft look). Imagine a letter U attached to the end of a shaft. Place another U on the second shaft and then turn one so that it fits into another. Connect the two U's using a piece shaped like a cross. Picture that and you will see how it continues to transmit torque even if the shafts are not co-linear. The guibo on our cars serves two purposes - it allows for some misalignment but more importantly, it acts as a cushion for torque changes. It is typically a rubber donut with alternating holes to connect to the ends of both shafts. Over time, the rubber starts to fatigue and will crack. Depending on how bad it is, you may hear noises as the shaft flops around a bit. A true U-joint does not wear like this. The bearings where the cross fits into each U will eventually fail. If you take a look under a big truck, you will clearly see the joint. They are superior for high-torque applications where the shaft angles are substantial. Hope this helps clarify. Regards. Last edited by Healey3000; 03-28-2012 at 08:55 PM.. |
03-28-2012, 09:20 PM | #4 | |
173
Rep 3,415
My car started making this same noise for about 60,000 miles. I've investigated it somewhat and think it is noise related to the driveshaft splines banging on each other. When in the driver's seat it sounds most like it is coming from the differential as pinion gear slop, but I cannot replicate the noise in the diff when I have the car on the lift. I plan additional investigation when I get time to pull the exhaust and be able to get a good look at the drive shaft. All I can say now is the noise once I noticed it around 111,000 miles has not become any worse with my car now at 171,000. I do not think it is the guibo as mine is still in very good shape. |
