e90 330d Rear Brake Pads
03-25-2012, 02:39 PM | #1 |
No Fear
13
Rep 278
Hello,
rear pads are down to 3mm, need to change them. Local stealer has quoted £230 for the work and they are in stock. On the off chance that sourcing independently maybe work out cheaper, can anyone recommend a reputable brand, I have seen them on eurocarparts by TExtar, PAGID or ATE, they are between £50 to £80. Cant be that difficult to change I imagine. Thanks in advance |
03-25-2012, 04:27 PM | #2 |
886
Rep 9,097
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
03-25-2012, 05:01 PM | #3 |
LSD - No, you're not seeing things
72
Rep 3,302
'Genuine' and 'ebay' in the same sentence, must be preceded with 'possibly'
Who knows. I would always buy critical parts from a know source, and with a credit card, and get that receipt! Eurocarparts are cheap, and Jurid are definately supplying OEM as my BMW rears had this branding. Pad changes on rear is around a 30min job both sides. Dont forget you will need to repalce the rear pad wear sensor too - essential and about £15. I would say £150 at most indy garages for this work.
03-26-2012, 06:53 AM | #4 |
No Fear
13
Rep 278
Thanks Guys, c3bmw have 2 sets of pads and 2 sets of rear sensors up for 106 squids...Labour mine, find a procedure from on line somewhere..
I assume a set means a pair of pads per wheel.. |
03-27-2012, 05:50 AM | #5 |
118
Rep 2,216
Drives: E91 330d M Sport
They should come as an axle set - ie 4 pads.
Just how many Yorkshire sheep can you fit inside one exhaust?
03-27-2012, 03:21 PM | #6 |
38
Rep 547
Rear genuines are made by Textar iirc (or jurid|)and just get a BMW stamp
Texter pads off ECP are half the price from BMW also check bmminiparts as they normally have genuines at a saving |
03-27-2012, 03:27 PM | #7 | |
38
Rep 547
These are only for a 316-320 going by that part number |
04-11-2012, 02:38 PM | #8 |
No Fear
13
Rep 278
I have been quoted £100 to have rear pads changed by Kwik Fit...sounds reasonable, buts its Kwik-fit...anyone with bad experiences with these fellows please?
04-11-2012, 03:15 PM | #9 | |
63
Rep 773
I'm sure there not all bad but surely there is an independant BMW garage local to you? |
