Tyre pressure not correct for M193 wheel ? (help)
03-25-2012, 07:40 AM | #1 |
51
Rep 593
Hi,
I was checking the tyre pressure today, and I got confused by the sticker next to the driver door... It mentions for 18" (M193, mixed 225ft/255re Category W): Full load: 2.9bar ft/3.4bar re (290kpa/340kpa). However when I read the inscription on the tyre it says never put more than 275kpa.... Now I am lost... What pressure am I supposed to use for 225/255 18" mixed tyre on a 325i ///M Sport ? I put 39psi/269kpa/2.7bar ft/re because of the inscription on the tyre... but is it enough ? doesn't match the sticker at all... Can anyone confirm how much they put on a 325i E90 M Sport with 18" 193M wheels, and what is written on their sticker ? Thanks in advance. Thierry Last edited by tbensous; 03-25-2012 at 07:47 AM.. |
03-25-2012, 10:15 AM | #2 |
922
Rep 5,538
tire pressure can be set to anything as long as it meets the minimum (printed on a car) and does not exceed the maximum (printed on tire). for best results refer to the manual because they have a table
03-25-2012, 04:41 PM | #3 | |
51
Rep 593
03-27-2012, 09:26 AM | #5 |
18
Rep 345
Are you sure you aren't looking at the pressures for if you will be driving over 100 MPH for long periods of time? 340kpa = 49.3 PSI according to the converter I used, and that's much much higher than what's printed on my door sticker. Mine is 32psi front 36 rear or 220kpa f 250kpa r
This is for a 2006 330i with sport package, which has the same size wheels and tires as your car. |
03-27-2012, 10:12 AM | #6 |
1569
Rep 29,202
Are you sure it says 2.75 bar in the tire? That seems little, I know I've seen 50 psi.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
03-27-2012, 10:31 AM | #7 |
124
Rep 5,627
03-27-2012, 02:33 PM | #8 |
18
Rep 345
04-02-2012, 06:29 AM | #10 |
51
Rep 593
I checked again, and figured the problem... There are actually to max written on the tire for the pressure. One says don't exceed max tire bed pressure 40PSI, and one says max pressure 51PSI. Which makes more sense. So I set the pressure to the BMW recommended value, which is below 51PSI anyway.
Thanks for the replies. |
