06 E90 - Diff Shot?
03-23-2012, 09:02 AM | #1 |
81
Rep 741
06 E90 - Diff Shot?
Mornin-
Seems I've been plagued by bad luck with this car recently. For no apparent reason, I began experiencing severe 'clunking' sounds from my 325i. Car only has 45k on it. I can't explain why this would happen without warning, or with such low mileage. I jacked up the rear end yesterday and put her in Drive and turned off the DSC. It was immediately apparent that the source of the clunking was coming from the differential area. Nothing has been taken apart at this point, but my symptoms are the loud clunking/knocking sound at varying speeds, the car lounging forward slightly, computer shows no errors on the dash, but have no checked INPA. If this is in fact the diff, what are my repair options? are all of the internals inside the diff serviceable? the list price for a whole new carrier is nearly $2k, for that kind of money I'm thinking LSD by Quaife, Wavetrac, Performance gearing, or OEM diff with shorter gears from turner motorsports (stock is 3.73, this one is 3.64). Moreover, i'm curious if my diagnosis is accurate, or do you really have to tear the diff down to see what's up?
['13 X3 SGM] [20" XXR550's in Black Chrome] [Lamin-X Tails/Fogs] [M-Sport Rear] [FOX Exhaust][H&R Sport Springs][RaceChip Ultimate][BMS N55 Intake]
SOLD-['06 325i TiAg] [19" VMR VB3 HYPERBLACK] [Blacklines] [OEM Xenon Conversion] [35% Tint] [M-Tech Rear] [M-Tech Front] [Black Vinyl Roof] [Slotted/Drilled Rotors, Cool Carbon Pads] [PBX] |
03-23-2012, 02:29 PM | #2 |
81
Rep 741
Anyone here have diff problems? can say what went wrong? please help. I'm trying to make an informed decision.
03-23-2012, 03:24 PM | #4 |
81
Rep 741
How many miles Rockyca? Any previous accidents? I had one two years ago. Also, I wish mine was only howling, at least then it'd be drivable. This is an extreme pounding sound while under acceleration, coasting, and braking.
03-23-2012, 04:07 PM | #6 |
Rep 78
I have the same problem, I posted in another category but should have checked here first. When I accelerate from a standstill, I get a loud metallic clank sound. If I let off the accelerator, it clanks again as the car slows down( only at slow speeds).
My neighbor thinks its a ujoint. I haven't checked under the car but that could mean a driveshaft replacement. Anyone know how hard it is to service a ujoint on our cars?? |
03-26-2012, 11:49 AM | #7 |
81
Rep 741
Polo any update on this?
does anyone have an LSD on their 325i's? experiences? recommendations?
03-27-2012, 01:30 PM | #9 |
81
Rep 741
Did you take the car in? What's the verdict?
03-27-2012, 02:19 PM | #10 | ||
141
Rep 2,217
Clunking or lunging could be either a chipped gear tooth or minor slippage... something i wouldn't expect from a car with only 45k miles. [mine has just under 70k and i'm just now starting to have an issue with it.] My problem is probably not related to your case; but because i have big wheels on my car, the bushings on the suspension are wearing down because of the extra weight's momentum to keep moving foward when slowing down... this causes a softer (more of a 'roll' of the wishbones) stop and an abrupt rear-end 'kick'. In the chain of events, when the rear-end sets back while in gear, the differential gets more abuse every time i stop. (it's hard to put into words with my short vehicle vocabulary, a video would show this and make more sense) ^^all this was explained by a German Tech that's fixed the same problems in the past^^ Quote:
The differential is a lifetime fill. If there is no obvious leakage, then there is still a sufficient fluid level. |
03-27-2012, 02:38 PM | #11 | |
81
Rep 741
03-27-2012, 04:28 PM | #12 | |
92
Rep 1,456
Not to start a war but lifetime doesnt mean it will all be there. Level could still be low. It can deteriorate and I still dont buy the term "lifetime" for any liquid in any environment.
03-27-2012, 07:45 PM | #13 |
37
Rep 608
sorry guys I have a scheduling conflict so I can't leave it there... They said they need to take apart the differential and see what part needs to be replaced. I will not have it in until 4/9.
03-29-2012, 02:47 PM | #14 |
"I know you know that I know you know..."
24
Rep 795
Drives: Sparkling Graphite E90 328i
I had a clunking from my rear diff before. For my it was the nut on the input of the diff had started to come loose. Mine only clunked when it first set off in either forward or reverse or when load is applied after a period of no load. I wanna say its part 6 on this diagram
http://www.realoem.com/bmw/showparts...50&hg=33&fg=05 |
03-29-2012, 04:34 PM | #15 | |
81
Rep 741
04-16-2012, 07:46 PM | #17 |
37
Rep 608
Family member picked her up, they replaced the entire diff. More info later, I'm going to swap cars next week to make sure everything is well. I don't have the receipt yet but I was told it amounted to $2,200... CPO charge of $50...
04-20-2012, 09:04 PM | #18 |
37
Rep 608
Picked up the receipt.... Brief synopsis:
1) Removed rear diff fill plug, checked for metal shaving, fluid was clean. 2) No hard spots or play from center bearing 3) Noise can be felt from the rear of the drive shaft and from the housing near the input shaft 4) Swapped drive shaft and axles from known good car, noise still present 5) Rear differential ordered and replaced, noise is no longer present No noise, car feels great, hope this helps. |
04-20-2012, 11:36 PM | #20 |
37
Rep 608
Thanks 60k, the noise has been present since purchase 33k... I thought it was normal until I had the vehicle on stands; When I turned the rear wheel back and forth it had a small amount of play that produced the clunking/clicking noise... U joints came to mind naturally, but you can't really see much due to the heat shields...
