How to install BMW TPMS
03-22-2012, 11:57 PM | #1 |
224
Rep 2,103
We thought that it would help out them members to go over the correct way to install TPMS in most aftermarket and OEM wheels. There will be slight differences if you have multi-piece or older wheels that are NOT TPMS friendly. They may require an adapter.
First you will need your new TPMS sensor and correct size valve stem. You should have an extra washer and holder stick with them valve kit. Attach Torx valve screw to base of sensor. Insert valve stem into new wheel. Make sure it is a standard valve stem hole. Add single washer. Attach valve stem nut. For BMW's BERU/HUF TPMS set torque tool to 35in/lbs. Tighten to torque. Most shops will have a TPMS testing tool to make sure the sensor is activated properly and ready to perform on your new set of wheels. Done. We would like to thank the guys at ShopTPMS for the great pics. Post up any questions you have. Thanks |
03-24-2012, 01:19 PM | #5 |
224
Rep 2,103
You will get an error code on your dash or i-drive depending on model. I have noticed that on vehicles with TPMS removed for long term (months) the error code will not go away without a flash from the dealer when a new set is put in.
03-26-2012, 01:52 AM | #6 |
BimmerPost Supporting Vendor
2042
Rep 25,989
Great post!
VMR|Wheels | 714.442.7916 |
03-30-2012, 12:12 PM | #8 |
81
Rep 1,142
ok, can you PM me, i need a set for the VMR 710s i just got.
TheLawrence3.00 |
03-31-2012, 06:35 PM | #10 |
224
Rep 2,103
03-31-2012, 06:39 PM | #11 |
243
Rep 578
pricing for a set of TPMS? Go ahead and PM me if you like. also is there a difference between BERU and HUF? Are they both BMW OEM manufacturers or are they the same company?
04-01-2012, 01:31 AM | #13 |
224
Rep 2,103
As of January 2012 HUF purchased the TPMS division of BERU. So now all BMW OE TPMS is manufactured by HUF.
04-02-2012, 07:58 PM | #16 |
243
Rep 578
04-02-2012, 09:25 PM | #17 |
14
Rep 245
04-02-2012, 09:53 PM | #18 |
45
Rep 148
quick question: i am about to buy vmr 710 and can i just use my old sensors from my stock wheels? thanks
08 E90 Monaco Blue 335i 6MT
04-16-2012, 05:59 PM | #21 |
224
Rep 2,103
