TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > N52 Single Turbo Options
      03-22-2012, 10:00 AM   #1
CobraMarty
CobraMarty's Avatar
619
Drives: 2007 328xi e90 + e92
Just thinking, how about a single turbo instead of the elusive Gavin or ESS supercharger.
I don't know it they would fit, but the options could be;
1) N55 stock turbo, manifold, and downpipe
2) HPF N54 single turbo manifold and smaller 300-350hp turbo
3) Vishnu N54 single turbo manifold and smaller 300-350hp turbo
You could use stock 335 intercoolers (cheap takeoffs) and some piping pieces.
      03-22-2012, 10:32 AM   #2
JJenE92
Drives: 2008 e92 328i
As I understand it the N52/N51's internals aren't reinforced enough to handle turbos, supercharging is the only way we're going to get forced induction on this platform and even that seems like a pipe dream.
      03-22-2012, 10:56 AM   #3
CobraMarty
CobraMarty's Avatar
619
Boost is boost. Supercharger or turbo it doesn't know the difference. If you keep it to 6 pounds and 300-325HP you will be fine.
      03-22-2012, 12:17 PM   #4
mike-y
just another bmw douche bag
195
Drives: 1.9L of fury
yup.
if you could compare the gaskets between the exhaust manifolds, that would give you an idea if it the 335i parts fit.
      03-22-2012, 04:29 PM   #5
C ///M
C ///M's Avatar
53
Drives: '04 M3 & '07 X3 M-Sport
Honestly I've been looking at this route for my X3. I've kinda been looking at all possibilities from Gavin's S/C, to a motorswap, and now an N55 single turbo.
From a non-technical standpoint and maybe some "common sense" the n55 is sort of based on the n52 with a single turbo added whereas the n54 was based on the m54 engine.
Taking the various bits from the n55 (injectors, turbo w/manifold, intercooler, etc) and fitting to the n52 should be straight forward. I figured since both motors had valvetronic, double vanos, etc, all the sensors should be the same and tuning should be "easier". I'm thinking replacing the cylinder sleeves with something stronger should be a good start towards some insurance. My version of the n52 is rated at 260hp (I don't know why the extra 5hp over the 330i or z4 3.0si). So an extra 40hp from a stock n55 setup should be no problem. Following that thought, getting a stock n55 software profile should be cake to load.
We'll see what I find out when I get some time to plan. So far this is just theoretical. I had my mind set on a motor swap, but my last one was an s52 into an e30 and electronics was not a concern back then.
      03-22-2012, 06:13 PM   #6
Johnny D
Johnny D's Avatar
64
Drives: 2006 BMW 325i
2006 BMW 325i  [9.16]
There are no cylinder sleeves in the n52.
      03-22-2012, 06:52 PM   #7
CobraMarty
CobraMarty's Avatar
619
Off the N55 could use the turbo and manifold, use someone's N55 take off downpipe, use your vehicle specific take off stock 335 intercooler.
Other parts- adapter to connect N55 downpipe to 328 exhaust, air filter and tubing, intercooler piping, tuning.
      03-22-2012, 08:02 PM   #8
C ///M
C ///M's Avatar
53
Damn, well that explains a lot... Dumb question, but are you 100% certain of this?
      03-22-2012, 08:05 PM   #9
Bavarian Tech
Bavarian Tech's Avatar
267
Drives: 335i
2006 330i  [10.00]
Straight from BMW
"The cylinder bore consists of an Alusil structure, there are no iron cylinder liners as with previous
6 cylinder designs. The cylinder bores cannot be machined, however this design still allows for
planing of the deck surface if needed."
      03-22-2012, 08:36 PM   #10
C ///M
C ///M's Avatar
53
Originally Posted by msbc721 View Post
Straight from BMW
Thanks for the clarification guys. Well that sucks.
      03-22-2012, 10:06 PM   #11
mike-y
195
is the N52 an open or closed deck design?
      03-22-2012, 10:25 PM   #12
SavvyByNature
21
Drives: 2015 - SO M4
While getting my car dyno tuned today (more on that soon), they had a professional drifting team there dyno'ing their turbo'd e46 ME. Their engine guy told me it's possible to turbo/supercharge the N52 engine, but the engine would have to be sleeved due to the magnesium block. He said it should be able to handle 6psi boost without issue.
I don't know how valid his answer is... but he had their 3.0L engine putting out around 700hp on the dyno.
      03-22-2012, 10:26 PM   #13
Beemw335
62
Drives: 335i
Simple: buy a 335
      03-22-2012, 10:45 PM   #14
CobraMarty
CobraMarty's Avatar
619
Originally Posted by Beemw335 View Post
Simple: buy a 335
Don't want one. Did they ever get the HPFP problem fixed? How about that direct injection and those carboned up intake ports. Don't they still have PCV oil blowing issues that catch cans don't fix. Hows your insurance bill?
Go play in your own sandbox and leave us 328 owners alone. TY.
      03-22-2012, 10:48 PM   #15
kiwi29
Team iTouge
kiwi29's Avatar
121
Drives: 09 M-Tech 328i
I've been doing research about this as well, from what I concluded, if you'd wanna boost higher than 6 psi, you'd need a air cooling kit. Far past the intercooler, you'd need : oil cooler kit, meth and water injection or nitrous, and a tempurature management system. A friend of mine turbo'd his civic and he recommended using an extra set of fans to cool where the intercooler and another set to blow the hot air away from the headers. Ceramic coated parts are highly recommend as well. Good luck in your endevours, when you find the golden ticket , klet me know . Ill be surely searching for more info as well!
Originally Posted by The HACK View Post
I'm going to use a very simple analogy, I hope you'll understand.
Driving is like having sex.
It really is. You can read up all you want about how to please a woman, you can look at all the diagrams in the world, but just like the clitoris, you won't know what the hell an apex is before you actually find it.
      03-23-2012, 01:29 AM   #16
e92mac
32
Drives: BMW 328i coupe 2010
Don't mean to be mean but
I love my 328i too. Something will come, if not just keep saving for your next car and make it an m3 instead of a 335.
      03-23-2012, 02:07 AM   #17
C ///M
C ///M's Avatar
53
Simple: buy a 335
And what am I supposed to do exactly?? In order to get an N55 engine, I have to get a new X3. First, I don't want a new X3 because its way too big. Second, I have a fully loaded M-Sport E83. In order to get the equivalent in an F25, I need to spend $60,000, or nearly $40,000 more than I did for my 20k mile '07. The way I see it, if I spend half that on modding my current car, well gee, there's a lot I can do for $20,000.
Just give it a rest already...
      03-23-2012, 02:10 AM   #18
C ///M
C ///M's Avatar
53
See, that was my original plan, but having just been informed that there are currently no sleeves in the N52, you can't add them without getting a whole new set of custom pistons that will fit.
I imagine that guy also doesn't know that the N52 isn't sleeved to begin with like a typical motor.
      03-23-2012, 05:26 AM   #19
SavvyByNature
21
Yea, I believe he knows. He does a lot of custom fabrication of parts.
I think getting our cars to the magical number of 300 whp would be perfect.
      03-23-2012, 08:07 AM   #20
TSM330i
2006 330i, TSM, Black, manual, sport
TSM330i's Avatar
878
Drives: '17 C2, GTI, Z4 3.0si Racecar
Simple: buy a 335
Oh gawd! Like we haven't heard that before
Why are you even on the NA board anyway? It would cost me about $20K to get a 335 to where my 330 is. NOT going to do it.
2017 Porsche C2 - manual of course
2015 GTI S
2008 BMW Z4 3.0si Coupe - because racecar
      03-23-2012, 10:11 AM   #21
BenġrTheBMW
34
Drives: 2009 135i
Say you just slapped a turbo on a stock N52 (325i) what exactly would happen? Just strain and reliability?
      03-23-2012, 04:10 PM   #22
mike-y
195
you shouldn't need to sleeve if you are just going to boost 6-7psi.
