PROcede FAQ somewhere? How does it really work?
06-11-2007, 09:21 PM | #1 |
14
Rep 122
Has Shiv ever made a good post on exactly how his PROcede works to make great power and keep everything safe?
I know that most other piggyback systems (UTEC, VAFC, ARC2, etc) that alter signals to or from the ECU can be tuned for good power but usually at the expense of the factory ECU no longer being able to compensate for things like altitude, temp, barometric pressure, knock, etc. Is this also the case with the PROcede and if not how is this unit so special? Also, IIRC the N54 runs 0.8bar (11.6psi) from the factory and the PROcede V1.45 91 octane is also approx 11psi, correct? If so where does all the power and torque come from |
06-12-2007, 08:00 AM | #4 |
14
Rep 122
I found a decent FAQ here http://www.vishnutuningforum.com/for...thread.php?t=2 but it doesn't address all the questions I posted in this thread.
-The BMW press release in the sticky of this section says the N54 runs 0.8bar which is the same pressure that Shiv claims with the PROcede. This doesn't make sense. -Does the factory ECU still have full control over atmospheric conditions, even with the PROcede manipulating the output signals? -Does the 93oct map run more boost than the 91oct map or just more timing? -Did anyone ever check the EGTs before and after a PROcede install? -Does the PROcede remove the 144mph speed limiter? Last edited by Cadence; 06-13-2007 at 07:29 AM.. Reason: 1 |
06-13-2007, 07:48 AM | #6 | |
15
Rep 467
Stock engine runs on 0.6 bar at sea level, but compensates for altitude reaching a peak of 0.8 bar. Procede, among other things, make the engine think it is always on a mountain, therfore.... 0,8 bar all the time. This is at least my understanding! No speed limit removal, maybe with Procede 2.0, but I havre read that a piggyback can not bypass the limiter in any case.
Current: e93 335 Msport, black sapphire on sanbeige, MT, 19" rims 225m, satnav, usb, CA, voice control, HBA, windstop, heated seats.
06-13-2007, 12:47 PM | #7 | |
Rep 4
06-13-2007, 01:04 PM | #8 | |
Moderator
270
Rep 4,481
Cheers Eugen |
06-13-2007, 09:22 PM | #9 | |
1577
Rep 3,888
1) I've seen the A/F graph from a Procede car on Dyno and it looks good. But has anyone specifically measured the knock sensor signal during WOT on the road? 2) Any recommendations for technique to avoid destroying the manual transmission with that extra torque? (Besides "just take it easy"...) 3) How does one need to drive to get that claimed 1 or 2 MPG increase? Thanks. |
06-14-2007, 11:40 AM | #10 |
14
Rep 122
06-14-2007, 11:58 AM | #11 | |
96
Rep 2,587
I don't think you can measure the knock sensor directly without BMW software. All I (and maybe the pros?) can do is look at the total timing advance stock vs. under boost and "guess" if knock retard is kicking in. Anyway doing this is a basic component of tuning and I'm sure it was done. |
06-14-2007, 01:05 PM | #12 | ||||
44
Rep 428
It has the ability to, but we are currently not offering that feature because of the liability reasons attached. |
06-14-2007, 05:46 PM | #13 | |
14
Rep 122
Dustin@Vishnu wrote:
We (335 owners) really need to get rid of the top speed limiter. Surely there is a disclaimer form or waiver that we could sign to get the limter removal feature? So many tuners (APR, GIAC, Turner, Diablo, etc) remove the limiter and I don't think there has ever been a legal issue surrounding any of these. If I order T-rated tires from the Tire Rack I don't have to sign a form saying what car they are going on. If Shiv was to install a PROcede into a car himself without the limiter maybe there could be an issue, but shipping them out it should be fine. |
06-14-2007, 06:01 PM | #14 | |
96
Rep 2,587
They will correct me if I'm wrong, but there is also a concern about traction control when the speed limiter defeat is in play. |
06-14-2007, 06:32 PM | #15 |
14
Rep 122
06-14-2007, 06:58 PM | #16 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
06-17-2007, 09:22 AM | #18 | ||
1577
Rep 3,888
However, even after you set your tune, conditions are dynamic and monitoring this signal would provide some important feedback. For example, if the car was filled with bad gas for some reason, or started running too lean for conditions (problem with boost control), or got too hot, the engine could be repeatedly knocking, regardless of diligent tuning. The driver would pretty much always be oblivious to it. |
06-17-2007, 04:09 PM | #19 |
14
Rep 122
06-17-2007, 04:50 PM | #20 | |
96
Rep 2,587
Next week I'm expecting a portable wide band setup in, and will be adding in addl fuel to see how much boost I ran run before knock retard kicks in. |
06-17-2007, 05:27 PM | #21 |
I'm just here for the turbo
Rep 327
Do you (or anyone else) have any data on the fuel system, i.e. how much over stock the fuel pumps, fuel rails, and injectors can handle before needing to go bigger (and which component(s) will need to be upgraded first and at what power levels do we reach the threshold)? I'd assume not until a turbo upgrade, and even then...
Current Rides: 2007 BMW 335i Sedan 6MT Montego Blue, 2004 Subaru Impreza WRX STi (for sale), 2004 Mazda RX-8 6MT
Fondly Remember: 1988 Porsche 924S, 1992 Mitsu 3000GT SL, 2001 BMW Z3 2.5i |
06-17-2007, 07:12 PM | #22 | |
1577
Rep 3,888
I used a replacement ECU for an RX-7 R1 that tended to run very rich as a safety measure for avoiding knock under higher-than-stock boost. Was really too rich, and rather wasteful, like how they tend to run race cars. Flames would shoot out the back. (Warmed up, it still managed to pass emissions, even with downpipe instead of pre-cat, and just a high-flow cat.) |
