General G-Max AS03 vs. Kumho Ecsta 4X
03-20-2012, 03:24 PM | #1 |
130
Rep 1,029
Drives: 2019 440xi Gran Coupe
I'm looking for new tires but not sure which would set to get.
Recently bought the VMR V718's 18x8.5 et35 18x9.5 et33 Tire size: 235/40/18 265/35/18 Will be using these tires for daily drive. Any rim protection on these tires? Narrow tires? Will any of these tires be stretched? I also noticed that the Ecsta 4X are heavier and has a higher load. Does that mean it can handle minor potholes better? Any comments is greatly appreciated! |
03-21-2012, 08:45 AM | #2 |
Moderator
369
Rep 4,745
I can't speak for stretch or rim protection (can't imagine they would be much different in that regard), but we do have a full test of the two tires compared here :
http://www.tirerack.com/tires/tests/...&affiliate=AH8 They are very close to each other with the Kumho 4X having slight advantages over the General in dry grip and some other areas, but the General having slightly better wet traction. Hard to go wrong with either tire.
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum. |
03-21-2012, 01:36 PM | #3 |
770
Rep 1,270
I've driven on the General G-Max AS03 for 10,000+ miles now, and I have no complaints. They are my daily driver and handle great in dry and wet conditions. The treads look cool and the treads still look brand new!
03-22-2012, 07:37 AM | #5 |
130
Rep 1,029
I am currently on stock 17 but will be upgrading to 18.
03-22-2012, 02:16 PM | #6 |
28
Rep 544
hmmm hard to say then, im currently running stock 17 sports right now to, well if this even helps at all but, 18's cleary better ride and performance, 19s more visual but not to sure how ride qaulity is. as for tire wise id probably choose the g-max over escatas.
03-22-2012, 06:03 PM | #8 |
130
Rep 1,029
Should I keep the same recommended PSI as my current stock 17" with RFT with the new 18" tires?
General GMax AS03 or Kumho Ecsta 4X basically deciding between Directional vs. Asymmetrical tires since they are so similar to each other. Is it that much more beneficial to be able to rotate tires from left to right the asymmetrical (Kumho 4X) compared to the stuck directional tires (GMAX AS03)? Will that alone increase the treadwear and/or have a more balance treadwear on the tires? Or maybe I am totally offside and it does nothing significant to rotate tires from left to right. Let me know. Thanks!!! |
