VMR Fitment Question
03-19-2012, 02:39 PM | #1 |
Rep 49
Car:2008 335xi
Wheels: 19" VMR V710 Front: 19 x 9.5 +33 Rear: 19 x 10 +25 Tires: Falken FK452 Front: 225/35/19 Rear:245/35/19 Can this fit the xi model 335? I really do not mind rolling fenders if need be. Also, how much room do you think this setup would allow for drop? If anyone has pictures of this setup on a xi, I would love to see! Thanks
| 2008 335xi | aFe Stage 2 | Avant Garde M359 F-19x9 ET35 R-19x10 ET25 Matte Black | Matte Black Kidneys | Smoked Headlights, Taillights, Foglights, and Side Markers | Matte Black Trim | Just Getting Started |
03-20-2012, 10:35 PM | #3 |
Rep 49
03-21-2012, 01:52 PM | #4 |
1569
Rep 29,202
Not sure if I'd go with htose tire sizes on xi.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
03-21-2012, 02:47 PM | #5 |
Rep 49
Why is that? wouldn't it allow me to stretch them some so I could sit lower with coilovers? or the xi not capable of dropping low enough to tuck them in the fender?
thanks
03-22-2012, 10:56 AM | #7 |
Rep 49
What size would you recommend for an aggressive fitment?
03-22-2012, 04:35 PM | #8 | |
Rep 49
I attached an image according to the fitment calculator on the top of the fourm. Thanks
03-26-2012, 02:01 AM | #9 |
BimmerPost Supporting Vendor
2042
Rep 25,989
You'll need to have a decent fender roll/pull in order for that to fit properly. I'd recommend a 19x8.5 +35, 19x10 +38 then space it out accordingly if it's not aggressive enough for your taste.
VMR|Wheels | 714.442.7916 |
03-26-2012, 02:33 AM | #10 |
Where'd my VTEC go?
481
Rep 6,067
You need to compare your front and rear wheel/tire sizes with each other, not against stock, because the xi needs all 4 wheels to have about the same rolling diameter.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
03-26-2012, 09:15 AM | #11 |
Rep 49
Thanks for the help guys, I will let you know if i run into any issues.
03-26-2012, 11:33 AM | #12 |
475
Rep 13,583
Drives: JB E92 335i
Although it was already mentioned, you need to need to be aware that the 19x10 ET25 is an aggressive fitment for your car. You'll need to roll your rear fenders to avoid rubbing issues. As VMR mentioned, the recommended setup is the 19x10 ET38 for a direct fit. As per the tire size, I would recommend that you go with the 235/35/19 up front and the 265/30/19 in the rear.
03-26-2012, 12:31 PM | #13 | |
Rep 49
03-26-2012, 01:30 PM | #14 |
Pro Hater
49
Rep 1,717
Front: 19 x 9.5 +33
Rear: 19 x 10 +25 This is no problem... 225/35 and 255/30 or 235/35 and 265/30 with a fender roll... done.
Username is now PSUSMU
04-04-2012, 12:44 PM | #15 |
Rep 49
Assuming you are accurate, what tire size would you ultimately recommend?
04-04-2012, 12:47 PM | #16 | |
Pro Hater
49
Rep 1,717
04-04-2012, 12:51 PM | #17 |
Rep 49
You did, I guess i should say what do you think would look better on my sky high sitting xi suspension.... I will be getting coilovers sometime this spring.
04-04-2012, 01:02 PM | #18 |
Pro Hater
49
Rep 1,717
225 on 9.5" is stretched and not necessary with et33.. so go with 235/265 if you don't plan on using spacers or slamming it
04-04-2012, 01:13 PM | #19 |
Rep 49
thanks!!!
