Repairing a RTF
03-19-2012, 01:41 PM | #1 |
35
Rep 410
Repairing a RTF
RFT* (cant edit the title)
Dealer said I have a nail in my tire… blah. Can it be fixed? Currently I am still using the tire; it slowly leaks air, but nothing too bad. thx |
03-19-2012, 01:44 PM | #2 |
21
Rep 546
I'm assuming you mean Run Flat?
No can do, it's 100% replacement only for RFTs. They cannot be fixed.
2011 335i X Drive Special Edition-Jerez Black 35% Tint All Around / 3M Rockguard / Weathertech/ PPK2 / 18&12mm Spacers/Lux H8 V3 |
03-19-2012, 02:01 PM | #5 |
145
Rep 2,809
Got my shit plugged and rolling on it currently...for at least 5k miles now. It all depends if you damaged the internal "run flat" material on it. Take it to discount tires, they can asses it and fix it for free if it's fixable.
03-19-2012, 02:02 PM | #6 |
Rep 160
It the inside is still in good condition, you can patch them. People say no because running the run flat tires with no air inside will ruin the insides, making it no good even after it's patched. Assuming you didn't run it with no air, you should be fine.
03-19-2012, 02:05 PM | #7 | |
3441
Rep 79,211
You are not supposed to plug them or patch them, especially if they were driven with no air. Some shops still do it, but keep in mind the potential risks.
It also depends on where the nail is... Quote:
03-19-2012, 02:12 PM | #8 |
213
Rep 1,782
If it slowly leaks out I suggest you keep checking the pressure and adding air. I got a mail in my tire the first day I got them. They fixed it because I didn't damage the side walls
Koni special active red, eibach pro-kit springs, Remus exhaust, stage 3 intake manifold,Stage 2 AA tune, BMW Short shift kit. Silicon intake pipe. M3 control arms front, M3 rear. ECS trailing arm with whiteline bushings. Purple powerflex subframe bushings. Yellow power flex upper shock mounts. Single mass flywheel OE weight.
03-19-2012, 02:15 PM | #9 |
70
Rep 975
...... Repair it. If you're going to replace it you might as well replace all 4 with non run flat tires. run flat tires are garbage
2009 BMW E90 328i | Xenons | MT | Space Gray | Beige-ette | CF Fabric Trim | iPod/USB | 20% Tints | Euro-Plate | Rear Fog Switch Lego Mod | Painted Reflectors | Performance Short-shift Kit | Style 197 Wheels | OEM Sport Suspension |
03-19-2012, 02:17 PM | #10 |
73
Rep 1,770
if you have a slow leak becuse of a nail or something like that and you have never driven on the tire while it's completely flat, yes you can patch it if its in a patchable spot.
if its flat and you drove on it, nope, not patchabale. replace |
03-19-2012, 02:17 PM | #11 |
36
Rep 564
I would just repair it....did it on my OEM tires to two of them and lasted until they wore down...then got rid of the RFT because they are complete garbage
03-19-2012, 02:57 PM | #13 |
douchebaggo
186
Rep 972
America's Tire patched mine for free. Ran it until it was completely bald with no issues.
You can patch it if the nail is not close to the sidewall and you have not driven on it with zero pressure. Don't believe anyone who tells you otherwise. |
03-19-2012, 03:20 PM | #15 |
25
Rep 691
yes, you can repair run flat tire much like a regular tire, patching will be better than plugging the hole. and also depends on location of the hole too, if its in on the sidewall or near it, forget it, you shouldn't even repair a regular tire if the hole is on or near the sidewall anyway
however, big disclaimer here, you are doing this at your own risk, if you have patched the tire and doing 100 (or 50?) and you hit a nail, you are increasing the odds of a blow out and obviously, you can forget about any law suit, because the manufacturer clearly stated that you must replace a damaged run flat tire |
03-19-2012, 04:03 PM | #17 | |
173
Rep 3,415
Just get it fixed. |
03-19-2012, 05:25 PM | #18 |
157
Rep 276
The tire can be fixed assuming you did not drive on the tire without air and that the nail is not in the sidewall. Most people don't understand that the only reason dealers say that a run flat needs to be replaced is because when you drive on it without air, it damages the side wall. I would advise you to have the tire patched rather than plugged.
03-19-2012, 06:09 PM | #19 |
1911
Rep 13,104
Bought a plug kit for 7 bucks at O Rielys
Did't even take the wheel off the car . Pulled screw out
reamed hole put in plug ran for a month on it and it wasn't leaking. Got a new set of tires but from what I read the plug should have lasted as long as the tire does. Also I can do 4 more plugs with the kit. |
03-19-2012, 10:50 PM | #20 |
196
Rep 2,485
I've plugged my own RFTs on two separate E90s for 6 years. Never had a problem. So long as you haven't run the tire at zero psi for more than a few miles or at high speed, you should be fine. The nail cannot be in the sidewall or close to it. It has to be in the tread that contacts the pavement.
Tire dealers want to sell tires. If they tell you it can't be patched/plugged, walk away. Dealers that do will charge about $25 to do it.
2006 E90 330i (retired)
2009 E90 335i (retired) 2012 E70 X5 50i M Sport (retired) 2016 F10 535i M Sport |
03-20-2012, 06:39 PM | #21 | |
1646
Rep 4,877
RFT's are nothing more than normal tires with extra ribs on the sidewall to keep them stiff with no air. It's not like they are magic or anything. As long as the ribbing isn't destroyed (aka driving a long time without air) they are fine plugged. |
03-20-2012, 08:13 PM | #22 | |
El Capitán
521
Rep 2,652
+1,000,000,000,000 RFT's are perfectly patchable. Most places wouldn't patch them if the nail is on the sidewall or within two fingers of the sidewall... |
