BBS RGR with 5mm spacer?
03-19-2012, 10:55 AM | #1 |
150
Rep 485
Want to push my fronts out a bit with some spacers - they're 18x8.5 ET38. Anybody know (without me having to pull one off) if BBS RGR's are beveled where they meet the hub? I don't want to have centering issues if I go with a 5mm spacer.
I could try a 10mm spacer with its own hubcentric extension, but I'm not sure if ET28 in front is going to stick out farther than my rears (18x9.5 ET33). e90 LCI. |
03-19-2012, 11:48 AM | #2 |
411
Rep 3,049
Drives: 2009 BMW 335d
What tire sizes you going with for front and rear?
03-19-2012, 12:40 PM | #3 |
Pro Hater
49
Rep 1,717
9.5" et33 still sticks out 8mm more than 8.5" et28.. you'll be fine depending on tire size/ride height. I think BBS are chamfered/beveled on the hub, but not 100% certain.
Username is now PSUSMU
03-19-2012, 01:21 PM | #4 |
150
Rep 485
Cool, thanks - I'm running 225/40/18 and 255/35/18 PSS, which run pretty wide. I'm on sport suspension with front lowering spring perches, but still a lot of space there.
I'm going to give the 10mm a shot, they should fit the best and if they're not going to be sticking out too far, will look better too. |
05-03-2012, 02:24 AM | #6 |
150
Rep 485
Finally received the spacers (and studs & lugs) and installed everything tonight. I'm really happy with the results - the 10mm spacers make the fronts look much more in line with the rears and no worries with centering. Exactly the look I was trying to achieve.
Thanks! |
05-04-2012, 05:10 PM | #8 |
Ex-Diesel Driver
63
Rep 2,000
Do you guys sell those? I'm not aware of any companies that have a hubcentric spacer under 10mm. I need a set, but I don't think rear hub extenders are available either... hurry up VAC.
FS: HRE Center Caps http://www.e90post.com/forums/showth...post13972317l] |
