Help with changing seats
03-14-2012, 07:25 PM | #1 |
13
Rep 228
Hello all,
Im planning on replacing my current seats with sport ones in next few days, but looking at the front seats today im just a bit confused with what to do with the seatbelt (the part which bolts into the outer sides of the front seats) how do i get access to that bolt?? please see pics for the bit im referring to cheers |
03-15-2012, 05:31 AM | #3 |
32
Rep 849
Drives: 640d GC / 420i XDrive
Disconnect the battery before removing the seats and don't reconnect until the new ones are in and connected.
If you don't do that then you'll trigger an airbag fault warning light which you will need to have reset by a dealer or someone with the appropriate kit. |
03-15-2012, 07:59 AM | #4 | |
13
Rep 228
cool cheers for the help guys - knew it must have been something trivial |
03-15-2012, 02:32 PM | #5 | |
11
Rep 126
03-15-2012, 05:01 PM | #6 | |
Straight 6
11
Rep 167
But a question comes to mind: Does that mean you could disconnect any airbag connector ie the one behind the steering wheel airbag, or the ones under the seat - with the ignition off, replace the connectors, then turn the ignition on and it would trigger no lights/warnings..? |
03-15-2012, 05:06 PM | #7 | |
166
Rep 2,445
Drives: 330d M sport
Garage List 2006 335d [0.00]
2006 330D M Sport [0.00] 2012 320d sport [0.00] 2006 Bmw 330d M Spo ... [6.66] 2007 320d M sport l ... [10.00] 2006/56 320d m spor ... [0.00] 2005/55 M Sport 330 ... [0.00] 2007 320d m sport ( ... [0.00] 2005 320 Cd m sport ... [0.00] |
330d M Sport Tourer / Arctic White / 403M Alloys / Privacy Glass / Logic 7 / Heated Leather Seats / High Beam Assist / Bluetooth / Nbt Nav / Auto Lights & Wipers / Front & Rear Park Control /
03-15-2012, 08:26 PM | #9 |
886
Rep 9,097
To OP, Bring the chair in the forward direction (to max).
Use screwdriver to remove the C cover. It is not that easy. There are three plastic clips retaining it. Use the middle one clip of C cover to remove it. Approach it from the bottom (middle clip) and with screwdriver, push it in (toward the chair) and up. Do not try from any other place, otherwise you may break one of the clips. You must have T50 to remove your seats. Always, Always disconnect the battery, unless you have proper equipment to reset airbag lights.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
03-15-2012, 08:30 PM | #10 | |
886
Rep 9,097
What if battery is connect and your triggered airbag? And if you do not disconnect the battery, and try to fiddle with passenger seat, you can trigger airbag light (even if car is turned off but key is in the ignition), especially if you kneel on passenger seat which may break co-driver occupancy sensor mat.
03-16-2012, 05:11 AM | #11 |
11
Rep 126
you cant trigger a light unless the car is turned on. only way it will come on is if you make a mistake with a connection and turn the car on, but that will happen regardless of battery
03-16-2012, 06:50 AM | #12 |
Straight 6
11
Rep 167
So disconnecting battery is the same as not switching the car on at the ignition?
03-16-2012, 06:53 AM | #13 |
Straight 6
11
Rep 167
Dude no disrespect but what's a 'co-driver' when it's at home??
03-16-2012, 07:10 AM | #15 | |
886
Rep 9,097
My mate was kneelin on passenger seat and broke the occupancy sensor mat, and airbag light came up. Car was switched off, but key was in, and radio was on.
03-16-2012, 07:11 AM | #16 | |
886
Rep 9,097
Lols, it freaking American term which sometime stays in your mind, and you simply type it.
03-16-2012, 07:12 AM | #17 |
886
Rep 9,097
Exactly, why risking when you can avoid it.
I have seen somebody here, who fiddled with his seats without disconnecting the battery, and later he had to look for somebody to reset. Ended up paying £40 to reset it at his local indi. So 5 sec V/S resetting airbag light. you guys decide....
03-16-2012, 07:30 AM | #18 |
11
Rep 126
i work with cars and deal with air bags all the time ive never had a light come up. ive had the seats out of my e90 a fair few times as well never a prob myself
03-16-2012, 09:20 AM | #19 | ||
Straight 6
11
Rep 167
that's exactly what we're trying to assess here.. is there a risk associated?
I'd be enlightened if someone else could confirm this. |
03-16-2012, 11:59 AM | #20 | |
13
Rep 228
03-16-2012, 02:07 PM | #21 |
886
Rep 9,097
You can have your radio / cd on without the iginition on. Try it, and it stays on for approx 20 minutes and will switch off automatically.
03-16-2012, 06:10 PM | #22 |
11
Rep 126
when the key is in/radio is on the air bag controller is also on that was why the light was triggered. (not the case with all cars but is with the e90)
