TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Valve cleaning/blasting
      03-14-2012, 03:53 PM   #1
phil200tdi
phil200tdi's Avatar
112
Drives: 335i M Sport E90 LCI manual
Does any one know anywhere in the UK who offer intake valve cleaning? Ideally the walnut shell blasting method.. I have spoken to a few people to no avail!!!
Car: e91 330d with Viezu map
Gone but not forgotten: 2010 Jaguar XFR (Cat-back exhaust, pulley, intake mods and map), Highly Modified E90 335i LCI M Sport Manual (circa 480BHP/500lb ft)
      03-14-2012, 06:56 PM   #2
Nigelo
30
Drives: E92 335i se
It's been on my mind too, especially since my car probably had a life a short journey, low octane fuel life before me - ripe for carbon build-up.
But until I start having issues, it'll be on the back burner. How many miles are on yours? I'm just over 40k.
      03-14-2012, 08:21 PM   #3
fastloop
40
Drives: E92 335i M Sport
I just had mine done at Birds while my HPFP was changed. It made sense to do it at the same time as they had to get the intake off to get to the fuel pump. So after a quick inspection to see the horrors of 55K, it was time to clean them. The valves were cleaned chemically with brushes and lots of scrubbing and Denis spent a good few hours getting them nice and clean.
Here are a few pics of the state as they had started to loosen up the crap on the valves.
Unfortunately I was busy talking to Kevin as they finished cleaning them so I don't have any photos of the final state. I saw them around mid way through and they looked a lot better than the above photos. Car is now back to full power after a new HPFP and cleaned intake/valves. I was actually surprised how bad my dying fuel pump were affecting performance and it feels like I got 30-40 BHP back.
      03-15-2012, 02:33 AM   #4
phil200tdi
phil200tdi's Avatar
112
Birds is not far for me!
How much was this service if you don't mind me asking? Pm me if you prefer!
Mine is on 80k miles!
      03-15-2012, 04:20 AM   #5
doughboy
doughboy's Avatar
1545
Drives: 2018 M2 Comp 6MT
Grim!
The manual cleaning method (seem some clips on the US forums) seems to work well, just softening it with solvents and brushing / scrubbing it off.
Just need a wet vacuum with a tiny attachment to suck out the debris as you go, obviously turning the crank to make sure each valve is fully shut!
      03-15-2012, 07:36 AM   #6
fastloop
40
You are probably better off asking them for a quote as my intake was already off because of the HPFP change, so I don't have an exact price. The valve/intake cleaning is about 3-4 hours + time for taking the intake off/on + test drive.
      03-15-2012, 01:31 PM   #7
phil200tdi
phil200tdi's Avatar
112
I'll give birds a call to discuss!
Cheers
      03-15-2012, 03:26 PM   #8
m1bjr
LSD - No, you're not seeing things
m1bjr's Avatar
72
Drives: Baby F36 Gran Coupe
Cheap fuel will have NO impact upon this type of carbon build-up discussed in this thread - direct injection fires fuel right into the combustion chambers
This buildup at the intake valves is down to oil from the crank breather system (or any oil in the charge air pipes)
      03-15-2012, 03:36 PM   #9
phil200tdi
phil200tdi's Avatar
112
I just managed to pull a SES light and code:
29D0 Misfirings, cylinder 4
Plugs changed a couple of weeks ago to rectify this - to no avail. I'll try to switch coils with another cylinder and see if the code travels.. if not could be injector or worst case carbon buildup.
Steve, you have a similar mileage to me - have you cleaned the valves yet? Mine just does long runs at motorway speed so hopefully the worst of the carbon is getting burnt away...
      03-15-2012, 04:18 PM   #10
neil@JuicedUpTuning
neil@JuicedUpTuning's Avatar
14
Drives: BMW 135i
Why BMS released their Oil Catch Can!
      03-15-2012, 04:28 PM   #11
phil200tdi
phil200tdi's Avatar
112
On my list of mods with the bms dp fix and CDV delete.. Then I think I'll have the full set of all your products.
Oh no wait LED angel eyes.. Want them too!
      03-17-2012, 07:26 AM   #12
phil200tdi
phil200tdi's Avatar
112
I'm getting bored of limp mode triggering now!
I think given the plug change seemed to improve things, I'm gonna go ahead with replacing the coil in cyl 4. Seem to be £50 inc vat and del on Bmminiparts - any one know any where cheaper?
      03-17-2012, 07:38 AM   #13
surrey 335i
22
Drives: 335i E91 sport, 123d + others
what fault code reader do you use? need to buy one.
      03-17-2012, 09:15 AM   #14
makkan00
makkan00's Avatar
886
Drives: F83 and F36
What happened after chaging the plug? Did you get the code on a different cylinder or same one?
Bmminiparts are cheaper with OEM parts.
You can find them cheaper on e-bay / GSF car parts / Euro car parts, but onus is on you to take that risk, especially when difference would be £10-20 pounds.
After changing the coil, reset the ecu or clear all the codes to avoid any further confusion.
All the best.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play
      03-17-2012, 10:30 AM   #15
neil@JuicedUpTuning
14
Drives: BMW 135i
JB4 has built in code reading and deleting
      03-17-2012, 12:33 PM   #16
surrey 335i
22
sorry new to all this stuf, what is a JB4?
was looking at the ones on ebay that are £20-£70.
      03-18-2012, 11:45 AM   #17
phil200tdi
phil200tdi's Avatar
112
http://www.juiceduptuning.co.uk/shop...duct.asp?ID=26
      03-18-2012, 12:13 PM   #18
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
Anybody tried THIS?
      03-18-2012, 03:35 PM   #19
neil@JuicedUpTuning
14
Drives: BMW 135i
To read and clear codes including the shadow codes you really need a BT Tool or a JB4 IMO
Originally Posted by RimasRS View Post
Anybody tried THIS?
To clean off the carbon deposits? Will work but manual chipping off will still be required
      03-19-2012, 05:14 PM   #20
m1bjr
m1bjr's Avatar
72
Ermmm... no.
Too scared LOL!
I think I have pinned my occasional stutter and rough start issue at last.
I too suffered sporadic misfires on cyl3 too, and very rarely a limp.
Swapped over after cleaning, both of the VANOS control solenoids.
No more error coded there or limps, as from the freeze-frame timing the limp was directly linked to VANOS valve on outlet.
However, I always suspected multiple issues and this seems to be the case.
Replacing coilpack (I had a couple of spares on shelf from a member on here) appeared to fix the missing.
But maybe it was only the biggest and most obvious issue, probably on the same cylinder.
Plugs were done by matter of routine a few thousand ago, no change and not replaced for a specific reason other than age.
This last weekend she started really lumpy, smoked a bit and stank of fuel.
A quick blip soon cleared it and it ran fine all week again.
A classic symptom of a sticky injector dribbling fuel into a shutdown engine.
It does this very rarely, normally after a thrash when its shutdown hot and fuel rail pressures will be high.
But, it tells me I have an injector acting up, and its likely cly3 as this is where I got the occasional misfire code.
I may try pulling them and getting them ultrasonically cleaned.
Did this myself in a lab once and it made a massive difference to an old Vauxhall I used to run.
As for carbon....
I read SO MANY threads on this but not one single person can catagorically say it fixed anything.
In fact appart for a little obstruction at high velocity (possibly roughness at small throttles) i fail to see what carbon in the intake will do.
Sure, its the reverse of gas-flowing the intake port, but it wont make 'that' much difference.
Certainly dont see how and oily intake will cause the errors people think it does.
Hey-ho - its all good fun!
I am at 70k or so IIRC.
PS- datalogging the HPFP fuel pressure was quite telling, as I thought this was the root cause of all the rough running and lumpt start.
However the rise of pressure and the actual pressure looks great, its always stable and gets to target quickly and cleanly every shift.
Still feel a slight surging on full bore sometimes, intermittant and never any codes. Must be an injector...
The HPFP job would be an inlet off, so if going to do that then the inlet might as well get cleaned too. Hopefully no need to go there.
      03-20-2012, 02:09 AM   #21
phil200tdi
phil200tdi's Avatar
112
I guess you needs BT/INPA to log fuel pressure etc?
The valve cleaning sounds like a pig of a job.. If my hpfp were on the way out then I'd definitely have it done whilst in there.
      03-20-2012, 04:36 AM   #22
Alpina_B3_Lux
Alpina_B3_Lux's Avatar
263
Drives: Audi R8 LMX, BMW M550i xDrive
2009 335i  [8.90]
If you have the correct walnut shell blasting tool then it is actually quite simple from what I have heard. But if you don't, and you have to manually clean every valve from every cylinder with a toothbrush, then it certainly is a pig of a job and ideally needs at least two days (to let the valves soak in cleaning fluid before brushing them off).
I've ordered the BMW blasting tool and will hopefully be able to document how this is done in the next 2-3 weeks or so.
Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
