where to get custom internals?
03-14-2012, 02:37 PM | #1 | |
Team iTouge
121
Rep 2,101
Planning on going old skool and building the motor! Now who makes custom pistons and cams and what not? I heard that the compression has to be almost the same and I was nervous about installing mopar pistons and rods. Aparently the old chargers could work too even tho its a V8. Any idea where to get these items done at?
03-14-2012, 03:19 PM | #3 | |
Team iTouge
121
Rep 2,101
Damnit the clerk told me it was in aisle 4! But seriously tho, if a single cam can have aftermarket internals, why can't we? Maybe I shoulld have said aftermakret.. anywho, throwing on the bolt on basics seems boring af and too much money for little gains. The supercharger is nice but I wanna make some true hp
03-14-2012, 03:30 PM | #5 |
1086
Rep 1,912
The N54 has forged crankshaft, pistons and con rods. I'm not sure if the parts are a direct swap to an N52 but that'd be one way to do it. I don't know of any aftermarket company that produces forged internals for these cars except for VAC.
You'll spend thousands on all of the bolt-ons you could potentially buy and maybe see 20hp from them. Not worth it IMO, and no need for forged internals unless you go FI. |
03-14-2012, 04:54 PM | #6 | |||
Team iTouge
121
Rep 2,101
Nothing else handles like a bimmer. And I'm not gonna downgrade to a older year or get a 335 with cash I don't have.
03-14-2012, 05:34 PM | #7 |
92
Rep 1,456
It has been said that the cams we have are already the best they can be. Theyre light (hollow), strong, and an aggressive and optimum profile.
Personaly think a stroked N52 is the way to go. There are a few compani9es that make a kit but it is upwards of $10-12k Gets you like a 3.2 or so liter car, but over 300 HP and probably sounds nasty. |
03-14-2012, 06:30 PM | #9 | |
1086
Rep 1,912
03-14-2012, 07:27 PM | #10 | |||
Team iTouge
121
Rep 2,101
Lol I was planning on it later on but I wanna beef the n52 up and see how good it gets, if I can stroke it and make it spank on a m3, id rather keep the n52 and some money cuz the motor alone is expensive not to mention the new tranny, new wiring harnesses and I also have to weld on a m3 rear end to compensate for the powering being made and the cost of having someone install it. But nice idea tho Quote:
03-14-2012, 07:51 PM | #11 |
92
Rep 1,456
http://www.noellemotors.de/BMW_3_series_E90.219.0.html
You basically replace all the internals. The rods are probably different lengths, different crankshaft profile. Basically increasing the stroke of the engine and increasind displacement while maintaing a high Compression ratio. I say it would sound nasty because I think it would have a bubbly angry sound if stroked. You tube some stroked motors. |
03-14-2012, 07:53 PM | #12 |
92
Rep 1,456
3.2l engine (basis BMW N52 B30)
for the following BMW models: BMW E87 130i BMW E90 330i saloon, touring BMW E60 530i saloon, touring BMW E63 630i coupé BMW X3 3.0 BMW X5 3.0 BMW Z4 roadster, coupé manual and automatic gearbox modifications to standard engine / scope of delivery: 1 crankshaft 6 pistons 6 connecting rods 2 catalyst pipes 1 end silencer technical engine dates: cylinders 6 bore 85,00 mm stroke 93,00 mm effective capacity 3165 ccm compression ratio 10,8 engine power: max. HP 306 HP/6700 min-1 (BMW 330i series 258HP/6600 min-1) max. torque 347 Nm/2900 min-1 (BMW 330i series 300 Nm/2500 min-1) (The engine has to be factory standard) maximum speed: all cars plus 29 km/h in comparison to series print version: |
03-14-2012, 09:25 PM | #14 |
59
Rep 741
Drives: E87 130i
As much as I love building stupid motors, it will be more cost effective and nicer to drive if you do an S65 conversion.
Also gives you a good basis for further power, I know I get bored easily... |
03-14-2012, 10:20 PM | #15 |
151
Rep 2,638
Great convo going here guys. Don't have a clue what stroking a motor is but I will research it after this. Main problem with AT it seems though is the inability to take a lot of extra HP. How, if at all, could the AT be upgraded with the engine?
03-14-2012, 10:41 PM | #16 | ||||
Team iTouge
121
Rep 2,101
03-14-2012, 10:44 PM | #17 | |
Team iTouge
121
Rep 2,101
Stroking the motor is creating a bigger bore for your pistons and for the AT, id say upgrade your diff. And possibly your gears. I'm not too sure if they make aftermarket gears though? Then again you could learn how to drive stick lol its a lot of fun and many more possiblities without lag
03-15-2012, 12:42 AM | #19 | |
151
Rep 2,638
How can the piston travel further? Is there additional room that is tapped with accompanying parts? |
03-15-2012, 01:38 AM | #21 | |
92
Rep 1,456
Different rods, crank, pistons. |
03-15-2012, 02:57 AM | #22 | |||
Team iTouge
121
Rep 2,101
Getting an NA wasn't my choice really. But id rather start from an error free lighter platform than a 335 and a m wasn't gonna work in the long run being as gas prices suck and oil isn't cheap either. But thanks for the support
