Brake Pad warning
03-13-2012, 06:32 AM | #1 |
70
Rep 275
Brake Pad warning
Morning guys,
A couple of weeks ago, my iDrive gave the following error: What is strange, my front pads were replaced 2k miles ago along with the discs. The rear pads, when i checked a week before this error, were showing 10k remaining. When you go into the service info menu, i get this This shows -- remaining miles for both front and rear! The car has a bmw warranty, and the dealer i used have said that the rear brake pads have triggered this, but they still have about 4mm remaining which they suggest will last another few thousand miles. They have said i shouldn't change the pads yet, but they can't stop this error coming up every time i start the car! Is it normal for it to show no distance remaining for front pads when it's only the rears that need changing? I found one other user with a similar error on another forum and he said it was an error with the OBC that his dealer reset. Any ideas? I think the BMW dealer's suggestion of having to have that warning and a light on my dash for thousands of miles is ludicrous! Thanks, Tom.
Previous: 2002 E46 330i M-Sport (m54b30 LCI), 2007 E92 335D M-Sport Coupe (m57), 2003 z4 3.0i (m54b30), 2010 E92 325D M-Sport Coupe (n57 LCI), 2019 F36 430i M-Sport Pro Gran Coupe, 2018 F36 440i M-Sport Pro Gran Coupe MPPSK
Current: MY2021 M550i, Aventurin Red, Ivory Nappa, Comfort Pack, Tech+ |
03-13-2012, 07:09 AM | #2 |
76
Rep 1,518
I had the same issue on my 335i. Brake pads were only about 8k old and were showing that they needed replacing. When I remove the wheel to check, I noticed they were fine with plenty of material left on them.
I have a Bavarian Tech cable so I just adjusted the miles remaining to change using my laptop. |
03-13-2012, 07:16 AM | #3 |
70
Rep 275
So BMW should be able to do this really rather than just leaving it!
Thanks for the input.
03-13-2012, 07:23 AM | #4 |
76
Rep 1,518
Maybe you could try a manual reset:
http://wiki.bavariantechnic.com/index.php?title=CBS Scroll down to e60 and e90 |
03-13-2012, 10:50 AM | #5 |
886
Rep 9,097
Leave it for dealer to deal with it especially if it is under warranty.
Take it back to them and ask them to sort it for you.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
03-13-2012, 10:55 AM | #6 |
153
Rep 3,730
It appears your brake pad sensors (1 front and 1 rear) are either broken or not installed properly.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
03-13-2012, 05:54 PM | #7 |
127
Rep 1,604
If its under warranty have the dealer replace the rear pads and see if it takes care of front problem too.
2014 Alpine White 328i M Sport | M Performance Exhaust | M Performance Front Splitter | M Performance Carbon Fiber Spoiler | M Performance Grills | M Performance Pedals[/SIZE]
______________________ |
03-14-2012, 05:34 AM | #8 |
38
Rep 547
My pads are down to around 4mm at rear also and still shows 12k miles on i drive,but my MOT station suggests i change them now.. £170 fitted by dealer (£85 for the pad kit)
If mine had the errors up on i drive i would prob just go and get them changed now TBH Rear pads seem to wear loads more than front? Last mot 5000 miles ago rears were 11mm |
