Walnut blasted Intake valves
03-12-2012, 11:54 PM | #1 |
Life is better with burnouts
98
Rep 611
Drives: BMW
I used
http://www.harborfreight.com/portabl...kit-37025.html and http://www.harborfreight.com/25-lbs-...dia-92150.html as well as a vacuum. I did not make an adapter plate for the vacuum and blaster, which did make a big mess. I covered open valves with a rag and plugged the necessary pipes. The only problem i found with this setup was the tip of the blaster was small, so i could not fully reach the end of the valves. The engine could be turned by jumping the starter with a wire. After putting everything back together, it took a couple turns to start but then ran fine. Results I was not expecting huge results because i could not clean everything at the bottom of the valves. However, the car is so much more rev happy. and pulls nicely. People who haven't cleaned their valves should. Last edited by TheeGovernor; 03-13-2012 at 05:04 PM.. |
03-13-2012, 01:46 AM | #4 |
164
Rep 2,556
OP: how many miles on your car?
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
03-13-2012, 05:31 AM | #5 |
Big Boost Addict
52
Rep 689
Cool, did not know these machines were this cheap! I love Harbor Freight...not the best quality but still the tools available are amazingly affordable and work longer than expected.
Thanks for the post! Hope to do this soon... |
03-13-2012, 02:01 PM | #7 |
king of the hills
92
Rep 2,915
Drives: 2011 M3 w/ESS55, 2001 540i/6
$840!!! Which dealer is trying to rip you off that bad?
03-13-2012, 02:39 PM | #8 | |
17
Rep 251
The good thing is that these gasket are relatively affordable and should be replace. I guess it is always better to be safe then sorry. I walnut blasted my friends Mazdaspeed 3 and it did wonders for his car. I can't wait to do it to mine.
2008 E90 335i, Cobb Ap, ETS CP with TiAL Q BOV, Cyba Air Scoops, BMS OCC, M3 Rep. Front, V-Lip, M-tech Rear, BMW Performance Kidney Grill, M-Tech trunk Spoiler, ACS Roof Spoiler, OEM Blacklines, H&R Sports, Koni Yellow Sports And Apec EC-7.
03-13-2012, 02:50 PM | #9 |
113
Rep 1,347
Drives: 2011 335d
There is no way that should be $840 bucks. I just took the intake manifold off my e36 over the past weekend and it took maybe an hour to remove everything. The N54 really isn't all that much different.
I would definitely replace all the gaskets just to be on the safe side... otherwise you could end up with some strange idle problems caused by a leaking manifold (common e36 problem) |
03-13-2012, 02:58 PM | #10 | |
BMW
71
Rep 974
03-13-2012, 03:49 PM | #12 |
155
Rep 3,730
$650 is what I paid the dealer. I would say between $400-600 is a fair price, I was just in a hurry.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
03-13-2012, 04:55 PM | #13 |
98
Rep 611
Drives: BMW
secretsquirrel-If you have a little car knowledge and read all the diy's, you will be fine.
jephs-I reused the gaskets and put grease on them and not leaks yet. But for 30 dollars, i would buy the gaskets. cvc- 77,000 and the guy who owned it before me did oil changes at 15,00 mile intervals Tony- I didn't replace the gaskets;you probably should depending on miles The most import thing when using the tools i used is to make or buy an extended nozzle so you can blast far down into the valves. |
03-14-2012, 06:15 AM | #15 | |
263
Rep 2,563
Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
03-14-2012, 07:58 AM | #16 |
422
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
Harbor Freight is awesome!
03-14-2012, 12:06 PM | #17 |
Rep 92
was also planning on doing this this summer, was thinking about using sodium bicarbonate (baking soda) which is a common blasting medium, a little less abrasive than walnut shell, and water soluble. Would definitely make a vacuum attachment but it would still probably make a mess..
03-14-2012, 04:11 PM | #20 |
79
Rep 1,617
My local dealer charges up to $1000 for walnut blasting. That's just crazy. This harbor freight stuff would be an awesome alternative!
Performance Seats, Exhaust, Splitters, Pedals, Steering Wheel / RB Turbos / M3 CF Roof / Brembo GT BBK 355/345 / Rollcage / Forge FMIC / Quaife LSD / Öhlins Road & Track / M3 Suspension Parts / Solid Subframe Bushings / Vorshlag Camberplates / Megan Racing Toe Links / LeatherZ Gauges / Extended M3 DCT Paddles / ER Sports OC / AR OC / Aux Radiator / AR DPs / Alpina TCU / COBB Pro-Tune
09-10-2014, 07:44 PM | #21 |
42
Rep 321
w blast
How about $300 for the walnut blast here in NJ
MHD/Wedge E60 flash/Alpina TCU /Fuel It st2/Dinan OC/RB inlets/Helix Fmic/Vrsf DP/Forge DV/BMS DCI/BMS CP/TC Kline SA/swift springs/MF lsd/OEM PE mod/front and rear M3 links/M3 strut brace/Powerflex race rear diff,camber link bushes/DEV diff brace/Megan toe arms/AKG Race subframe bushes/Hotchkis Sway Bars/18 TSW nurburring/Michelin PSS/BMW M perf 370mm Hexon RR600 on the way
