03-12-2012, 04:54 PM | #1 |
46
Rep 582
Bmw 1m clutch upgrade
So in looking for a clutch upgrade i research all the clutches for the 08 n54 135i and ACT or HPF seem the best.
But in looking around for info on the 1m i thought since we have an n55 shifting linkage i have no clue if we have a n55 clutch or an n54 clutch. In doing research i found out that the clutch disk in the 08' 135i differs from the clutch disk in the 11' 135i - we have the same clutch disk as the 11' 135i which the part # ends in 8492 - our flywheel also differs from both the 08' and the 11' but from our flywheel to the 11' the flywheel differs from 1 single number in the part number. Example -11' - 3249 - 1m - 3250 Trying to find a clutch upgrade that works Does anyone have any info on clutch upgrades for the 1m?!!!????!? |
03-12-2012, 05:05 PM | #2 |
450
Rep 1,358
Didn't Turner recently buy a 1m? I'd call them. Or call some of the vendors you mention above and ask them?
Please let us know what you find out. I'm curious to know too! BTW, you getting slippage? |
03-12-2012, 05:43 PM | #3 |
46
Rep 582
Umm when my clutch was i guess warmed up i did get a little slip when tested after going to the track.
I have 8000 miles. But today when i tested it no slip so i guess maybe the clutch plate was really warm |
01-31-2013, 08:03 AM | #5 |
European Editor
10528
Rep 22,992
I think ZF Sachs makes an upgraded clutch.
http://www.sachsperformance.com/Sach...4376_4587.html Here is ZF Sachs contact info... S-Performance GmbH Elbring 45 21217 Seevetal Phone: +49-(0)40-3999 211-8 Fax: +49-(0)40-3999 211-9 Email: info@sachsperformance.com I do not think Sachs has a US importer - yet. Acording to RealOEM.com the 1M and the N55 135i's use the same clutch disc... # 21217598492 http://realoem.com/bmw/partxref.do?p...ur=&series=E82
01-31-2013, 12:21 PM | #6 |
Rep 9
I bought 2 months ago a clutchmaster FX300 for my 1M...and now it's handling better with the power...and the clutch pedal now it's a little lower and heavier, but the shifts are faster...
01-31-2013, 01:09 PM | #7 | |
31
Rep 108
I found this http://www.performance-kupplung.de/s...mw/e82/1m.html |
01-31-2013, 01:28 PM | #8 |
291
Rep 2,898
FWIW, I'll likely go with a SPEC Stg. 2+ clutch with a steel single mass flywheel (also made by SPEC) when my clutch is in need of replacement.
Believe it's available from Harold at HP Autowerks and from Jake/Dzenno at ProTuning Freaks. Neil |
06-15-2013, 04:39 AM | #9 |
22
Rep 85
I hv the same clutch slipping on my 1m with 18,000 km on it. Thinking of clutch master but not sure which of their ranges I should go for. With the tune iv done I makes 100nm extra. Also do I need to change the flywheels? Any recommendation
06-15-2013, 08:41 AM | #10 | |
2616
Rep 2,819
Drives: e82 1M, f87 M2cs
Chutchmaster's website will tell you what kind of torque each setup can hold. Their clutches work really well. I used their street/strip clutch with heavy duty pressure plate in a prior car and it gave a noticeably firmer pedal, but was not hard to daily drive at all. I wasn't stuck in stop and go traffic very often, but when I was it got a bit tedious. |
06-18-2013, 06:13 PM | #12 |
Supreme Allied Commander
3812
Rep 54,307
Drives: F80 M3
Clutchmasters FX300 and FX400 have been the two best sellers for our 1M customers.
06-19-2013, 05:14 AM | #13 |
22
Rep 85
06-19-2013, 10:23 AM | #14 |
Rep 20
09-18-2013, 06:14 AM | #15 | |
Rep 9
http://www.1addicts.com/forums/showthread.php?t=854391 I've done it with the CDV removal. |
09-18-2013, 08:06 AM | #16 |
85
Rep 2,438
There is good thread on e90post http://www.e90post.com/forums/showth...highlight=spec
After reading it all I think you will not go with single mass flywheel. For now best bet is SPEC stg2+ or 3+ with oem DMF. There was a few reports that ACT clutch held a good power though very short like for 10000-12000 miles |
09-26-2013, 06:17 AM | #17 |
Rep 11
I have a situation with my 1m. THe milage at this moment is 11k km.
Stock clutch had been changed on 6k km and I installed SACHS Perfmomance. Yesterday it began slip. My specs - 400 hp and 600 nm. What is better to install now? Should I change flywheel? The usage is daily with some traffic jams and i don't care about heavy pedal. On winter season I'm going to upload stock program. any sugestions? |
09-26-2013, 07:27 AM | #18 | |
85
Rep 2,438
Take SPEC stg2+ with oem dual mass flywheel for daily drive replace flywheel and when your gear box will be down vood to replace crankshaft rear seal.
09-26-2013, 05:30 PM | #19 |
3812
Rep 54,307
Drives: F80 M3
09-29-2013, 10:10 AM | #20 |
73
Rep 549
Still hesitating and don't know what is better choice for a daily drive:
-Spec st.2+ and Steel Single Mass Flywheel -Clutch Masters FX300 ans keep the stock Dual Mass Flywheel Don't want to have any rattle noise. |
10-03-2013, 12:52 AM | #21 |
Rep 11
what about CM FX350? any opinions?
I didn't find FX300 here http://clutchmasters.com/shop/?page=...11&ToYear=2012 I'm planning to order it and install with stock DMF for daily usage and track days. |
10-03-2013, 02:56 AM | #22 | |
85
Rep 2,438
Anyway it is recommended to replace DMF with new one. |
