whining noise at high rpm?
06-08-2007, 01:49 AM | #1 |
17
Rep 163
I'm just wondering if it's normal for the N54 to be making high-pitch sound at 4K rpm and above? The sound is pretty noticeable inside the cabin.
2018 F87 M2
2014 F30 328i M Sport Alpine White/ Coral Red leather |
06-08-2007, 01:58 AM | #2 |
/|/|uffin/|/|an
11
Rep 196
I hear a whining noise in the cabin as well.... Mine isnt the engine though.... I actually took it in to service to check it out and they said its a fan that kicks on to cool the electronics in the dash(near the glove box area)... They claim it's normal but it drives me nuts!
06-08-2007, 01:58 AM | #3 |
36
Rep 526
this shouldnt happen unless u have AA Xede or Procede. I have the Xede and u can hear a pshhhht in the high rpms due to more boost and also i can hear the turbos spool up harder and louder. Mike.
06-08-2007, 02:03 AM | #4 | |
17
Rep 163
2018 F87 M2
06-08-2007, 02:06 AM | #5 |
17
Rep 163
My car is bone stock with 1,400 miles. The sound doesn't seem like it's coming from the turbos, since I can hear it during deceleration as well. To me, it sounds similar to the whining noise from my EVO's tranny (which is normal).
2018 F87 M2
06-08-2007, 09:16 PM | #7 |
29
Rep 957
Drives: 2022 X3 M40i
^ lol.
I was thinking along similar lines. The only whining I hear are the passengers complaining about my high speed antics. |
06-08-2007, 09:21 PM | #9 |
67
Rep 527
Do you only hear it on decel? The alternator has a one way clutch on the N54's that lets it freewheel when the motor spools down quick. Put the car in neutral and rev it to redline then let it come back to idle quickly. You'll hear the alternator wind down slowly.
If it's not that, figure out if it's engine speed dependent or vehicle speed dependent. Does it come through the radio speakers?
10 AW on fox E90 M3 with 2 pedals, gentleman’s ride
08 AW on fox E92 M3 also 2 pedals, a bit more rowdy |
06-08-2007, 09:33 PM | #10 |
32
Rep 420
The latest software update should fix this. I checked with the dealer already and they said by uploading the latest software into the car, the noise will go away! I haven't had the chance to bring my car in for the update but once I do, I hope the sound will go away. Will update you guys once I get it done!
06-10-2007, 11:37 PM | #11 | |
17
Rep 163
2018 F87 M2
08-30-2013, 04:28 PM | #14 |
Rep 35
Back to the top. Recently my car whine on high rpm with full throttle only....power is there but never heard this noise before and I do have procede. Is this normal?
08-31-2013, 12:01 PM | #15 |
76
Rep 911
Could be turbo whine.. You can find examples on youtube.
BMW 335 E92 09 - Full options - DKG - MHD by Buraq - RB Next Gen - RB Inlets/Outlet - Forge Diverter Valves - AR Catless DP - Afe Intake - Helix IC - FuelIT Stage 2 LPFP - Ar Oil Cooler - PPK Water Cooler - M3 Suspension - JRZ RS1 Shocks - Eibach Pro Springs - Drexler LSD - BMW IS Exhaust - Carbon Endurance Brake Pads - Stainless Steel Brake Lines - M101 Wheels - Michelin PS2 - M-Tech Body - M-Strutbar
BMW M550i G30 2019 - BM3 |
02-27-2015, 10:49 AM | #16 |
217
Rep 1,909
reviving an old thread, I have a steady whine at all RPMs ... its pitch adjusts to RPM, I changed the serpentine belt, idlers, it didnt go away ... took the belt off and started the engine, no whine... I flushed PS fluid, didnt make a difference.... WTH is it
Mods: 7" VRSF FMIC, Forge DVs, RB PCV, BMS Oil Cooler, VRSF DPs, MHD, JB4g5, OFT DIYs: Walnut blasting : Trans Oil at 45k, w Filter at 65k : Diff Oil Flush @ 45k : WP&TS @ 69k : Alternator @ 79k --- E70d Alphabet Soup del 44.4k : JR Stg2.25 tune : Buzzken Catted Exhaust : Trans fluid drain/ fill (3 Qrts), both Diffs fluids flushed Wheels: Style 95s on PSSs (Sold): AG 359s on S04s : 162s on Blizzaks : Rohana RF1 Matt black
