E90/91 LCI Halogen AE as DRL - Done!
03-09-2012, 05:29 AM | #1 |
40
Rep 1,021
Drives: F11 530d M-Sport
Hi guys,
Just to let you know, this can be done without the harness that's talked about on the coding forum. To get the halogen light angel eyes as DRL (on all the time) and still working as welcome lights, the following lines need to be looked at in the NFRM. VERHALTEN_DRL_TFL drl_s DRL_TFL_MIT_BFD nicht_aktiv DRL_TFL_MIT_NSW nicht_aktiv DRL_TFL_MIT_BLK_V_GED nicht_aktiv DRL_TFL_MIT_SML aktiv DRL_TFL_MIT_KZL nicht_aktiv DRL_TFL_MIT_RL_BL_2 nicht_aktiv DRL_TFL_MIT_RL_BL_1 nicht_aktiv DRL_TFL_MIT_RL_BL nicht_aktiv The red ones are the lines I had to change but I've copied the others just to make sure. Once this is done, just go into the OBC and enable the DRL - Voila! Note that this is for cars with halogen LCI angel eyes, I'm not sure of the procedure for cars with Xenon lights but I believe it's roughly similar. Did my main beam flash on alarm, beep on lock & unlock, digital speed in OBC, closing window doesn't stop when opening door and digital speed correction while I was at it.
MY14 Space Grey F11 530d M-Sport
03-09-2012, 05:51 AM | #2 |
76
Rep 1,518
Did the cable work with your car without modification?
Good to see you've coded successfully, it seems quite complicated when you research how to do it. |
03-09-2012, 06:39 AM | #3 |
40
Rep 1,021
Yup, cable worked fine. I think for older cars you need to use the adapter you included but my E91 and E87 both worked fine as is, thanks again!
It looks a lot more complicated than it is, but point and click it's not.
03-09-2012, 09:16 AM | #4 |
76
Rep 573
Hi so what do I need to be able to do this??? I have halogen lights and car is 2011.... I don't have I drive just the obc....
/// 1M V O sadly gone
/// M5 2014 LCI gone.../// M3 2015..gone..Z4 35i2015..gone ///M135i 2015 Lci...gone/// M3 2016 Lci Suzuka Grey .gone Z4 35is 2016 Now here |
03-09-2012, 10:17 AM | #5 |
40
Rep 1,021
You need a DCAN cable, a computer running xp and Ncs expert. You have to code the car.
03-09-2012, 10:19 AM | #6 |
76
Rep 573
Thanks for that..... But it is over my head...... Lol
Will do without.. Thanks
03-10-2012, 03:29 AM | #7 |
886
Rep 9,097
Excellent mate.
We both have done the LCI headlights at same time. I thought about this the other day, but was not keen (there is a reason for it ) Basically I want to have control on these manually, rather than having them on all the time, when car is on. However I may require some information about coding, as I am not getting it right. I will send you pm and hope you dont mind replying. Cheers.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play Last edited by makkan00; 03-10-2012 at 08:07 AM.. |
03-10-2012, 04:42 AM | #8 |
40
Rep 1,021
Replied. Coding can be difficult to start, but once it works for the first time, it seems pretty simple.
04-05-2012, 10:55 PM | #9 |
Rep 28
Can I know how does the original code looks like?
Did you mean we just need to delete/change certain line to the one in red? So with this change, the AE will be lighted once the ignition is started? |
04-07-2012, 02:16 AM | #10 |
40
Rep 1,021
Yep, the top bit used to read drl_h and the bottom, nicht_aktiv. Those are the only linesi changed in the FRM.
04-07-2012, 04:05 AM | #11 |
886
Rep 9,097
I have done many including beep on lock / unlock, digital speedometer, windows down with fob, but my NFRM is old module to have these done as DRL's.
The other thing, I wanted to do was to keep the cluster on all the time (used to it on my previous car) but could not do it on my E90. Frob, give it a try and see if you can do it. Apparently I have NFRM1, and you should have NFRM2 or 3 in order to have DRL's and speedometer on all the time. Happy coding!
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
dumapuma0.00 |
04-07-2012, 04:16 PM | #12 |
40
Rep 1,021
Yeah I can do this too. Mines a July 07 build with FRM2(NFRM).
04-07-2012, 05:25 PM | #13 |
886
Rep 9,097
Frob, Can you activate welcome light (i.e Lights on when locking or unlocking) ?
or is it only available on FRM3 / E92?
04-08-2012, 07:53 AM | #14 |
40
Rep 1,021
Yep I have welcome lights. The taillights, door handle lights and angels all come on when you unlock for about 15s or so. You can change them to whatever lights you want though.
04-08-2012, 07:54 AM | #15 |
40
Rep 1,021
That all came as standard though rather than me having to activate it.
04-08-2012, 10:08 AM | #16 |
886
Rep 9,097
Well those are not standard on my car as I have FRM1.
Thanks for the info.
04-08-2012, 11:23 AM | #17 |
40
Rep 1,021
Upgrade it!
http://forums.bimmerforums.com/forum....php?t=1611769 http://www.ebay.co.uk/itm/07-BMW-E87...#ht_2866wt_922
04-08-2012, 11:40 AM | #18 |
886
Rep 9,097
Funny enough Frob, I did that research last night.
After considering cost involved, risk, coding, and chaging VO, I put this porject on my 'To Do' list. Thanks for your help mate. Really appreciate it.
04-08-2012, 01:04 PM | #19 |
40
Rep 1,021
Yeah, I reckon it'd be worth it. I'm not sure what FRM3 would give over NFRM(2) mind you?
04-08-2012, 02:49 PM | #20 |
886
Rep 9,097
FRM3 allows you to add 'Follow me home Lights'. It works when you press trunk button on the keyfob once.
Not worth of going for it just for that additional feature.
04-08-2012, 02:56 PM | #21 |
40
Rep 1,021
I thought I could do that by pulling the headlight stalk before I get out?
11-15-2012, 04:29 AM | #22 | |
84
Rep 396
