Intermittent 40mph whine - Quaife diff
03-08-2012, 06:03 PM | #1 |
47
Rep 791
Since having my Quaife installed a few hundred miles ago, together with M3 subframe bushes and uprated ARBs, I've noticed an occasional whine from the rear end when accelerating through 40mph. The load on the driveline has to be just right - it doesn't do it under hard or gentle acceleration, just moderate.
I initially blamed the diff, but the shop that installed it (Birds) assures me that a noisy diff would be noisy all the time, not just under specific loads. They suggested it might be the auto box as it was always happening in the same gear (5th), but I managed to repro it in sport mode in 4th tonight at the exact same road speed. Has anyone else ever come across anything like this? Any suggestions what I should be getting them to fix? Thanks in advance!
2021 G21 M340i XDrive | ACS springs and spacers
Previously 2019 VW Golf GTI Performance | H&R rear ARB Previously 2007 E92 335i SE auto | Quaife LSD | Birds B3 ARBs | Evolve Stage 1 Last edited by seanblee; 03-16-2012 at 05:16 PM.. |
03-08-2012, 06:48 PM | #2 | |
15
Rep 603
Sound anything like described in this thread:
http://www.e90post.com/forums/showthread.php?t=532595 specifically posts 1 and 32? Quote:
03-08-2012, 07:07 PM | #3 |
47
Rep 791
Yes, almost exactly! I guess I'm glad I'm not the only one, but it doesn't sound like you've been able to find a cure either Wonder where we go from here?
Previously 2019 VW Golf GTI Performance | H&R rear ARB Previously 2007 E92 335i SE auto | Quaife LSD | Birds B3 ARBs | Evolve Stage 1 |
03-08-2012, 07:19 PM | #4 | |
15
Rep 603
http://www.e90post.com/forums/showpo...80&postcount=7 I am thinking it's the drive shaft. I am likely going to have my shop replace the whole shaft next week I'll report back. Also based on communication with Autobahn335i he had the sway's put on at a later time and the whole subframe replaced due to an accident. So from this I am thinking these are not part of the problem, leaving only the drive shaft... |
03-09-2012, 01:45 AM | #5 |
47
Rep 791
Are you thinking the shaft was somehow damaged when the diff was installed? My shop has installed dozens of these, so I'd be surprised if that's the case for me, but I guess it's possible. Perhaps it's been there all along but had been damped by the standard subframe bushes?
03-09-2012, 06:51 AM | #6 | |
15
Rep 603
I think if there was a balance issue before you would know it, the bushes wouldn't mask this significant of an issue. |
03-16-2012, 04:37 PM | #7 | |
117
Rep 1,764
03-16-2012, 05:09 PM | #8 |
151
Rep 1,809
I read one thread where the support of the bearing was installed up side down. It can very easily be installed upside down, resulting in a vibration at certain mphs.
Here: http://www.e90post.com/forums/showthread.php?t=621437 See posts 16 and 17, and the rest... |
03-16-2012, 05:15 PM | #9 |
47
Rep 791
Birds tell me the centre prop bearing wasn't touched when my install was carried out, and there's no reason it should be touched to install the diff. I'm therefore hopeful this isn't my issue.
03-16-2012, 06:34 PM | #10 | |
117
Rep 1,764
03-16-2012, 06:58 PM | #12 |
15
Rep 603
03-16-2012, 09:18 PM | #13 |
117
Rep 1,764
It would be best to look at all things that worked on during the install. When the bearing are in good condition the noise is usually caused by lose race condition or possible a bearing race not being seated properly. It can be difficutl to see the with the eye as the diviation might be small. When the noise happen is subjective so it could happen for specific load/speed or all the time but it will be more prevalent when things warm. The nature of the noise is the bearing vibrating at resonate frequency so it can be damaging long term. Theis give you the idea why it happening but i not sure anyone can help pin point it
04-18-2012, 06:55 AM | #14 |
47
Rep 791
FTR, unbeknown to me, my car actually received Powerflex designed bush inserts instead of the OE BMW M3 versions. Birds have removed these and the noise is gone, so it's evidently a resonance issue that gets carried through the subframe bushes into the body but is absorbed by the standard sloppy bushes. I'm going to live with the slop for the time being.
Previously 2019 VW Golf GTI Performance | H&R rear ARB Previously 2007 E92 335i SE auto | Quaife LSD | Birds B3 ARBs | Evolve Stage 1 Last edited by seanblee; 04-18-2012 at 10:33 AM.. |
