seezed rod
03-08-2012, 05:09 AM | #1 |
11
Rep 344
Drives: BMW 335I M Sport
seezed rod
Hi guys right i have had tthe warning come up on my i drive screen saying that there was a problem with the DPF so i took the car to dick lovet in hungerford to get the problem sorted. just had a phone call and they are telling me that there isnt a problem with the DPF but they think that one of my rods are seezed and that they need to take the inlet manifold off to check at a price of £400 can anyone shed any light on this situation please.
335D
03-08-2012, 05:23 AM | #2 |
11
Rep 344
just had them ring me back and say it could be due to the swirl flaps can any help me out Swirl Flaps?
335D
03-08-2012, 05:35 AM | #4 |
11
Rep 344
Basically yes no signs of anything wrong just the warning light come on on the I drive about the dpf
335D
03-08-2012, 05:46 AM | #5 |
15
Rep 365
Drives: F32 435dx ms, E90 330d ms
How many miles has the car done?
03-08-2012, 05:47 AM | #6 |
Rep 499
In that case theyve taken the car out for a good thrashing to try and force a regeneration of the DPF and over reved it causing engine failure..
Or is it possible they meant a different rod? |
03-08-2012, 06:10 AM | #7 |
15
Rep 365
The 335d is an auto box which changes up before it over revs. Diesels are built pretty strong due to the nature of there design. Siezing a con rod would seem very doubtful to me.
I've yet to hear of a confirmed case of Swirl Flap failure on the e90. My brothers 335d has just ticked onto 123k miles with no such issues. Ask them which fault codes are logged. I assume the car has been serviced as required? |
03-08-2012, 06:35 AM | #8 |
11
Rep 344
Cars done 47k miles they wouldn't have take. It for a thrashing because you can't force the car to regenerate after the fault code has been logged you have to connect to the diagnostic tool and reset the codes. Then they force regen it in the garage.
Latest update there is a valve which moves the rod which has failed and needs replacing at a cost of £500 all in. Can't wait to get it back they gave me a corsa 1.4 as a loner talk about like for like
335D
03-08-2012, 06:48 AM | #9 |
1397
Rep 8,083
They can't possibly mean a con-rod.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
03-08-2012, 07:16 AM | #10 |
1545
Rep 8,970
03-08-2012, 10:52 AM | #12 |
Capt Slow
37
Rep 1,076
I can't see how a swirl flap rod would indicate DPF failure on I drive?
Swirl flaps can be blanked (no need on e90) with no issues so even without it working properly I can't see the problem. Be interesting to see what they do and if it cures your fault though. |
03-09-2012, 03:42 AM | #13 |
11
Rep 344
Pick the car up later today so I will let you know how it goes
335D
03-09-2012, 01:32 PM | #14 |
40
Rep 522
Sounds like a lot was lost in translation from the tech to the CS to the customer. You would think the CS's would pickup some common issues and have basic understanding of cars, but it's shocking how much confusion they can make because they haven't got a clue.
OP, I hope everything works out for you and they are able to explain what rod they think is the problem? |
