N51 Stage 3 Intake Manifold
03-07-2012, 01:47 PM | #1 |
Rep 34
Drives: 2008 328xi Coupe
I have a N51 and have been seeing that you can get the stage 2 AA tune if your car has the Stage 3 Manifold. How would I tell if I have it? is there other benefits with having it?
03-07-2012, 06:52 PM | #2 |
91
Rep 611
I got ESS instead of AA, it works really good. N51 has been detuned at factory, a tune will get you near 330i power. You should feel
more difference since u got heavier xi, from 2500rpm to 3200rpm you will gain about 20 extra torque, which is great for daily driving. I think with AA stage2's mid range and top end has been further tuned, but no one has a dynojet reading yet, I cant really compare with mine...
N51- PI - PE - ESS Tuned - SSK - CDV Delete - AFE Header - B12 - Mfactory LSD
03-07-2012, 09:19 PM | #3 | |
Rep 34
03-07-2012, 11:13 PM | #4 |
91
Rep 611
yea i am quite happy with ESS, freeway doing 70 to 80 u can now feel the pull, before its some what flat...
the tune pkg came with flash device for 899 though... u can probably get it cheaper if can get someone local doing ess flash without buying the device. or you can just get AA stage 2, i think it makes slightly more top end.
03-08-2012, 08:42 AM | #6 | |
Rep 34
Did you get your exhaust and intake before or after the tune? Did you notice any difference with those installed compared to stock? |
03-08-2012, 11:48 AM | #7 | |
91
Rep 611
best bang for the money is the tune, your 6th gear freeway crusing will never be the same. exhaust probably wont increase much power without the tune and intake, but im not disagree with those ppl think its their best mod, cuz it really sounds amazing.
03-08-2012, 11:51 AM | #8 |
91
Rep 611
you should get it tuned asap, there is really a 330i engine sleeping under your bonnet.
03-08-2012, 12:04 PM | #9 | |
Rep 34
I love the way the PE exhaust sounds but I think I'm gonna get the tune before anything else |
03-08-2012, 09:26 PM | #10 | |
91
Rep 611
you can hit up ESS and ask for the tuner name AJ on N51 flash, he might get you more power if your area has higher oct gas. Mine running 91 in CA, so he was hesitating on tuning it further.
03-09-2012, 10:13 AM | #11 |
46
Rep 1,487
03-09-2012, 11:28 AM | #12 |
91
Rep 611
easiest way is to check under your hood for "SULEV" sticker, if you have "ULEV" then its N52 without 3 stage manifold.
03-09-2012, 12:24 PM | #13 | |
46
Rep 1,487
http://www.e90post.com/forums/showth...ntake+manifold EDIT: Here is the intake manifold for my car from RealOEM.com. To me it looks like the 3 stage..could it be?!!? http://realoem.com/bmw/showparts.do?...56&hg=11&fg=40 |
03-09-2012, 12:48 PM | #14 | |
91
Rep 611
RealOEM.com pic sometimes are not same as actual part.
03-09-2012, 01:10 PM | #15 |
46
Rep 1,487
01-19-2016, 12:06 AM | #16 |
79
Rep 447
Drives: 2011 750i
So after reading this, I believe my n51 has the stage 3 intake manifold. Has any gotten their n51 tuned to see the hp difference?
01-19-2016, 07:11 AM | #17 |
413
Rep 1,286
I have a N51 with the AA tune and it added about 12 horsepower. The AA tune alone will not get you anywhere near the power level of the high output N52 in the 330i. It will add a noticeable amount of low and midrange power though and eliminate the annoying throttle lag.
2012 Jet Black 328i Coupe / ESS Tuning Gen. 2 Supercharger / Evolution Racewerks Oil Cooler / BMS Oil Catch Can / BMW Performance Exhaust with Dinan Y Pipe / Eibach Pro Kit Springs / Koni FSD Shocks / MFactory LSD & Differential Bushings / Performance Rear Trailing Arms / BMW Performance Strut Brace / Stop Tech Slotted Rotors / Hawk HPS 5.0 / SS Brake Lines / Brass Guide Pins / M3 Front Control Arms, 28 MM FSB, Engine Cowl, and DCT Paddle Shifters / Michelin PSS / APEX ARC-8
01-19-2016, 08:01 AM | #18 | |
460
Rep 4,531
Biggest opportunity there is with a tune is to restore drive ability. I have AA Tune, AA Headers, No Muffler and make 229 HP @ 207 ft-lbs of torque at the wheels. |
01-20-2016, 04:03 PM | #19 |
827
Rep 3,856
My N51 is dyno confirmed at 330i power levels after the AA tune. The torque is ridiculous, it feels like an N54/N55
01-25-2016, 08:45 PM | #20 |
12
Rep 85
Does anyone know exactly what the AA tune does if you have the N51 engine? Does it "activate" the 3 stage intake? Just trying to figure out what BMW did to "detune" it in the first place and what exactly is being done to take advantage of it. I have an 09 328i with the N51 engine, just got the tune this morning from AA but haven't flashed it yet, AA headers are enroute after getting Swain Tech White Lightening ceramic coating... should be a fun weekend.
01-26-2016, 05:00 PM | #21 |
66
Rep 675
1. All N51's have the stage 3 manifold
2. The AA tune will not give your N51 328 anywhere near 330 power. I dont care if you have a PE exhaust and a intake. You will need some some headers and a few more tweaks to gain the power of a 330. 3. What the tune will do is eliminate throttle lag and give you a butt dyno. If you have an Xi expect less results |
01-26-2016, 09:05 PM | #22 | |
2465
Rep 9,004
The AA tune is all pluses, you'll make more power everywhere, and leaves the door open for headers in the future. |
