How to rejuvenate leather?
03-06-2012, 09:41 PM | #1 |
My other ride is a Bianchi Infinito
96
Rep 2,767
Hey guys, I have black dakota leather and the 2 front seats have dulled out spots here and there where the leather is a lighter shade, some area a bit white and faded. Looks terrible. When I use Meguiars leather conditioner for example and it is moist the leather looks awesome, but as soon as it drys it looks the same again. Any suggestions? Also have one small spot where the leather has been scuffed off a tiny bit.
Thanks guys |
03-06-2012, 10:03 PM | #2 |
Rep 58
Drives: 2006 Barrique Red 325i
Leatherique is the best; need to find a warm day with sun for best results, however
03-06-2012, 10:07 PM | #3 |
Rep 126
Drives: 2011 E90 & F25
... greetings ...
i have used following three products by recommendation of many pros on this forum: i am assuming that your leather is in very good "shape" ... may i suggest the first 2 products ... Keep in mind you are working with the protective layer of the leather and not with the leather itself! 1. Swissvax Leather Cleaner Swissvax Leather Milk (amazon.com) (detailersdomain) 2. Leather Master Universal Cleaner (Leather Master Strong Cleaner) (Leather Care Vital) used on older leather Leather Care Protective Cream http://shop.unitersna.com/collections/leather-master (detailersdomain) 3. Leatherique Prestine Clean (used on older/worn leathers) Leatherique Rejuvenator (detailedimage) ... regards ...
DRIVE IT LIKE YOU STOLE IT |
03-07-2012, 07:11 AM | #4 |
1086
Rep 1,912
Not sure if you are but it wounds from the OP like you are letting the conditioner dry onto the leather before you buff it off? You should definitely remove it wet since you'll never get it off otherwise and that would be causing your problems. You say that the leather looks best when it is wet but that shiny coating is not desirable. The leather should have a uniform matte finish.
Try leatherique. Over time dirt, salt, old conditioner and body oils coat and clog the leather surface so that it gets that nasty shiny look. This product pushes all of that out and leaves the finish matte and fragrant after the cleaner |
03-08-2012, 12:29 PM | #5 |
15
Rep 368
i just made the leatherique switch.. see my review in this same section titled " leatherique in hand" i havent used anything but mothers but let me tell you.. leatherique is a bit messy and is a lot of work and time because you have to let it soak in but you will not be disappointed.. i was so happy that i am doing over the front seats bc i didnt do them properly the first time.. PM if you want help or advice
03-08-2012, 12:33 PM | #6 |
15
Rep 368
03-08-2012, 02:56 PM | #7 | |
144
Rep 216
Drives: 2017 BMW M2
this stuff can do wonders when used properly!!!
2016 750i X-drive
2017 GMC Sierra Denali 1997 MB SL500, 19"AMG replicas Past BMWs: E30 323i, E36 325is, E36 M3, E46 M3, E39 M5, E46 325i, E90 335i, F80 M3, F87 M2 |
03-11-2012, 11:17 AM | #8 |
96
Rep 2,767
Thanks for the replies. I know you everyone swears by Leatherique and I've seen some impressive before and after pictures.
But, my problem isn't with dirty leather. It's these strange white-ish blotches here and there. I refer to them kind of like "dulled" out leather. If I just rub my hand over them they go away and keep coming back. Only when the leather is moist will they go away, as soon as it drys it'll come up again. This is probably only something that happens with black leather. I'll try and get some pics if I can capture it with a camera. |
03-12-2012, 04:46 PM | #10 | |
144
Rep 216
Drives: 2017 BMW M2
Here's a link to the instructions for Leatherique (if you haven't read them yet): http://www.leatherique.com/do_it_you...irections.html Their site also has DIY instructions for re-dying leather.
2016 750i X-drive
