      03-05-2012, 12:12 PM   #1
OAM
OAM's Avatar
44
Drives: Sitting
Will these fit?
Can anyone tell me if these wheels will fit a stock 1M and maintain the the same look?
front : 19 x 9 +25 offset
rear : 19 x 10 +15 offset
Thanks.
      03-05-2012, 01:24 PM   #2
wkndwrrr
wkndwrrr's Avatar
Drives: 1M
Yep, they fit with no rubbing what-so-ever, but the wheels will look more flush than stock.
I'm actually effectively running a +20 offset upfront now, and it rubs the front left brake duct. But after 2 weeks of driving I seem to have shaved off enough of the plastic off the brake duct to no longer rub
      03-05-2012, 01:43 PM   #3
MDORPHN
291
Drives: AW 1M
The 1M does not have brake ducts. Do you mean the wheel well liner?
Neil
      03-05-2012, 01:58 PM   #4
wkndwrrr
wkndwrrr's Avatar
Drives: 1M
Neil
Lol whatever the proper term for the part of the wheel liner with the slots are
      03-05-2012, 02:32 PM   #5
Fundahl
Drives: VO 1M, 300zx TT
I think they are for fender/front bumper air pressure relief.
      03-05-2012, 07:40 PM   #6
Redlyne_mr2
12
Drives: 1m, mr2 turbo, Land Rover
What size tire do you plan on running. If you can stretch the rubber and run a narrower tire you should avoid from rubbing the liners. Are you lowering the car? If so what is it lowered with?
      03-05-2012, 09:46 PM   #7
OAM
OAM's Avatar
44
Drives: Sitting
Not lowered or any plans to lower. Want to just keep it stock. No clue what tire I'm planning on running, I guess whatever would keep it looking as stock as possible, could I run the stock tires? I also don't want to run any spacers or have any rubbing issue whatsoever. Grateful for any advice.
      03-06-2012, 11:09 AM   #8
OAM
OAM's Avatar
44
Drives: Sitting
I have to make a decisions on those wheels soon, can anybody chime in if I can run the stock tires on those wheels without any spacers or rubbing? Or if those wheels will fit and what tire sizes I should run to maintain the stock look without rubbing issues? Thanks.
      03-06-2012, 02:34 PM   #9
OAM
OAM's Avatar
44
Drives: Sitting
anybody have any input? I need to make a decision on these wheels today. using a wheel calculator it says my fronts would be pushed out 6mm and rears 10mm. Anybody know if that's too much or will cause rubbing? Anyone running similar offsets?
      03-06-2012, 06:36 PM   #10
OAM
OAM's Avatar
44
Drives: Sitting
Thanks.
Help! need an answer within a few hours. I did the calculations and the front will stick out 6mm and the rear 10mm. Is that too much and will it cause any rubbing?
      03-06-2012, 08:00 PM   #11
wkndwrrr
wkndwrrr's Avatar
Drives: 1M
sorry if I wasn't clear, you won't rub until you get to +20mm offset in the front
and even then you're not "rubbing" per se, as "rubbing" refers to tire on metal; which is bad. The rubbing will be with the plastic portion in the photo in your other thread. Give it a week and the tires will have made room for themselves.
So once again, no problems what so ever with +25mm
      03-06-2012, 08:19 PM   #12
OAM
OAM's Avatar
44
Drives: Sitting
Awesome! Thanks! Sorry for all the posts!
1addicts
