Evolve / Cobb
03-05-2012, 08:48 AM | #1 |
177
Rep 751
Evolve / Cobb
Not looking to start a tuner war here, just looking for some advice specific to my needs.
Had the Evolve stage 2 for a couple of months now and finding myself wanting a little more midrange. Don’t get me wrong car is quick and I love the smooth linier power delivery that the Evolve flash provides, however it just feels a little too linier in the higher gears and whilst I wouldn’t trade it for an on/off power delivery I feel like i'm wanting more. Been keeping my eye on Cobb, like the sound of the stage 2+ aggressive map and flexibility of map switching. Cobb seem to target more boost (around 16-17) which I’m pretty sure will deliver the additional mid range I’m chasing. Anyone have any knowledge or experience of both maps? Will Cobb stage 2 + aggressive deliver more midrange given the higher boost targeting? Last edited by 335i E92; 03-05-2012 at 10:01 AM.. |
03-05-2012, 10:43 AM | #2 |
112
Rep 2,621
Stack a jb4 on top of the evolve stage 2 tune. Add more boost in the midrange. Plus get benefit of steering wheel controls and gauge hijacking. Oh and meth integration should you want more!!
Car: e91 330d with Viezu map
Gone but not forgotten: 2010 Jaguar XFR (Cat-back exhaust, pulley, intake mods and map), Highly Modified E90 335i LCI M Sport Manual (circa 480BHP/500lb ft) |
03-05-2012, 11:51 AM | #4 |
112
Rep 2,621
No, you use a bespoke map (map 6) and input the boost you wish to target at a given rpm. There was a thread on stacking JB4 on Cobb recently here:
http://www.n54tech.com/forums/showthread.php?t=15047 same principle on the evolve map you have... |
03-05-2012, 11:55 AM | #5 |
263
Rep 2,559
I had GIAC stage 2 before going over to COBB (but more due to the compatibility with bigger turbos and bespoke map development possibilities).
The COBB stage 2+FMIC aggressive felt definitely more powerful than the GIAC stage 2 (which I dynoed at 433hp / 677Nm). GIAC targeted 16.5psi, COBB goes up to 18.5psi, which explains it. Also the boost ramps up more quickly with COBB. Hope this helps. Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
03-05-2012, 12:55 PM | #6 | |
177
Rep 751
03-05-2012, 01:30 PM | #7 | |
177
Rep 751
Dyno figures are impressive, how does the Cobb deliver on the road? Is it progressive / predictable? Cheers H |
03-05-2012, 02:13 PM | #8 |
112
Rep 2,621
Is 18.5psi with meth flowing?
Sounds very aggressive if not. I would say 100 octane race gas and/or cold temperatures would be recommended by Terry to run with boost this high..
03-05-2012, 03:15 PM | #9 |
30
Rep 540
I think Cobb run less advance timing, but crank the boost up instead. They taper it downwards as you head up the revs to keep the turbos in their efficiency range. This approach really does need a better intercooler and downpipes to keep the temps down.
Didn't realise they went up to 18.5psi though! |
03-05-2012, 03:21 PM | #10 | |
144
Rep 4,501
03-05-2012, 03:26 PM | #11 |
177
Rep 751
Not running meth and don't plan too, currently FBO 'ETS intercooler & AR catted DP's)
I feel 18.5 is a bit ott for stockers, was under the impression stage 2+ Cobb was 16.5 - 17 tops. |
03-05-2012, 03:26 PM | #12 | |
3441
Rep 79,211
As much as the turbo's are their efficiency range more boost still does create more heat. For anyone going to stage 2 boost its recommended to purchase an aftermarket intercooler. In fact if you talk to Cobb they recommend and intercooler as one of their first mods although its not required. The intercooler will provide better consistency pull to pull, keep intake air temps in check, which would allow for better safety margin, and overall engine safety. |
03-05-2012, 03:34 PM | #13 | |
144
Rep 4,501
Very good info. Thanks for that |
03-06-2012, 07:26 AM | #14 |
177
Rep 751
Looking on Cobb’s site they list the below Stage 2+ FMIC map options of which all require upgraded DP’s, FMIC and intake (which can be panel filter)
Drive map: Daily driving map with nice bump in power. Stock rev limiter. • Stock or Linier throttle option • Fuel: Prem 91 Sport map: Sporty map with a healthy performance increase. Raised rev limits. • Stock or Linier throttle option • Fuel: Prem 91 Aggressive map: Maximum power and torque. 93 octane fuels and above. Raised rev limits • Stock or Linier throttle option • Fuel: Prem 93 I’ve e-mailed Cobb to get a break down of boost targets set for each map and will report back. Also I’m confused regarding the requested fuel grade on the aggressive map as it states 93, Is this equivalent to our Shell V power / Tesco Momentum (99) or are we talking proper race gas required for the aggressive map? |
03-06-2012, 08:02 AM | #15 | |
14
Rep 454
93/94 Octane rating we need to use RON 98/99 like Tesco 99 or V Power If you want to run race fuel the VP MS109 or similar is available in drums |
03-06-2012, 09:40 AM | #16 |
177
Rep 751
03-06-2012, 04:27 PM | #17 |
177
Rep 751
Just had the below response from Cobb. Looking at the dyno results in the link I was pretty surprised how low the BHP figure was for stage 2+ FMIC aggressive was, only around 360. Does this seem correct, would have expected over 400 horses?
=============================================== Unfortunately there is no exact boost levels as your vehicle runs a load based system. Here are 3 map comparison on our dyno: 335i Stage 2 Map Comparision. http://accessecu.com/dyno/graph.php?...rgb3=000153000 Boost will change depending on the load. Please let me know if you have any other questions or concerns that I can assist you with. |
03-07-2012, 03:05 AM | #18 |
112
Rep 2,621
It will be wheel horse power. Add 10-15% for bhp correction.
03-07-2012, 03:07 AM | #19 | |
263
Rep 2,559
That should equate to around 430hp at the crank, if my dyno figures are to be taken as an example. Alpina_B3_Lux
03-07-2012, 03:08 AM | #20 |
112
Rep 2,621
Also temps are high at 91 Fahrenheit, could be humid too which will sap power.
03-07-2012, 06:55 AM | #21 |
177
Rep 751
Ok, makes sense now!!
Still by the dyno it's indicating that boost on the aggressive map peaks at 18psi around 4k rpm but dips backs down almost immediately an tapers off towards 12 by 6k rpms. Obviously any tune will shorten the life span of the turbo’s but is this considered a plausible boost target (even if a brief spike) for stock turbo’s and FBO’s? I won’t be tracking the car so it would only see these levels of boost for short burst whenever I feel like embarrassing an RS4 or similar. Last edited by 335i E92; 03-07-2012 at 07:02 AM.. |
03-07-2012, 08:03 AM | #22 | |
30
Rep 679
Untill a turbo upgrade shows up Ill be nowhere near those numbers with the n55...
335 - Öhlins//Swift//M3 front suspension//M3 subframe bushes//Quaife LSD//AR Design Catless//Forge Intercooler//Alcon BBK//Goodridge//AFE//RPI//Fenders - SOLD M4-Mineral Gray/Full Shakir Orange/DCT/M Ceramic/M Adaptive Susp. |
