335i JB4 and Meth Review
03-03-2012, 08:20 AM | #1 |
112
Rep 2,621
As I am laid up with an injured knee (cartilage damage and on crutches), I thought I'd write a quick update on the meth kit which I installed last weekend. The meth kit in question is the BMS WW Kit which is sold by Burger Motorsport and is fully integrates with their JB4 piggyback tune. more details on the kit can be found here:
http://burgertuning.com/meth.html The install went according to plan and took around 3-4 hours. The instructions were ok at best but it came clear after thinking it through a few times. Wiring in the JB4 was easy enough. The main problems encountered were in fitting the meth elbow - or more accurately removing the old rubber hose to fit the elbow. This hose is held to the charge pipe by a permanent metal band rather than a hose clip. Hence to remove the rubber hose I had to remove the air intake (Dual Cones in my case), remove the diverter valves, and remove the charge pipe. At first I thought the clip would need to be cut off using a dremel, fortunately I was able to break the join underneath using a screwdriver and hence didnt damage the chargepipe or the rubber hose - great as I will refit this when reverting to stock. Another annoying issue I came across was in trying to calibrate the meth pump, this requires a 1/16" allen key (the smallest one), the only one I had came from a cheap Chinese toolkit and wasnt perfectly sized - luckily my neighbour is a mechanic and had one close to hand but I had to wait a few hours for this rather than finishing the job early. The setup of the JB4 is easy, merely connecting the laptop as usual and in the meth tab setting the meth flow scaling and meth additive. These allow the JB4 to progressively control the meth flow based on revs and boost. I set everything up using the standard settings proposed in the install guide for 93Octane (98RON) - I think this targets 17-18psi in the mid range but could be wrong. I deliberately ran my windscreen washer fluid to empty so as to fill up with 50:50 meth/water. I bought the Meth and deionised water from Bonnymans in 25litre drums. I also bought a cheap hand pump off ebay which is great for filling an old 5 litre windscreen fluid bottle. 50:50 meth to water ratio is by weight and not by volume, hence for 5 litres I am running 2.85 litres of meth to 2.15 litres of water. Bleeding the air from the system was easy - activating the pump with the meth line in a container - I used a 500ml coke bottle which worked a treat. So how does meth work? This video really helped me out: Now that everything was in and working, time for a drive... Given that I had also just changed the spark plugs I wanted to get everything warmed up fully and working before using meth. I had previously had misfiring issues which i was keen to ensure had been rectified using map 2 - everything seemed fine - in fact more than fine, map 2 seemed to be much stronger than before as has been reported by other JB4 users updating to the new firmware. When fully happy that the car was running strong I switched to map 3 and set guage hijacking (boost on fuel and meth flow on oil). Slowly pulled out in first, short changed to second and nailed it. Cue two black lines of rubber! Into third and the thing really striking me was the torque and just how quickly I was needing to reach for the next gear. My car when healthy was no slouch (0-100 in 10.18) but it seemed to now be on a whole new level - perhaps even a second faster to 100!!! I haven't managed to do any dynolicious timing yet and due to my injured knee cant see this happening soon, but it has made a huge difference in the few days I have driven it. The way that the boost and meth comes in is very linear and progressive, there is no massive lag or kick in the back, just a wave of torque which gets bigger and bigger and bigger. Grip is now more of an issue than ever, the car squats in 3rd like it would in 2nd ordinarily, 4th pulls as hard as 3rd too, its quite disorientating and I got caught out thinking I was at the top of 3rd but actually top of 4th gear --- Oops!! (Private road of course ). It may be a placebo but it seems to sound louder too when really nailing it - time will tell. Suffice it to say I am extremely satified with the system, I would guess that if you say stage 1 adds 60 hp, stage 2 (dps and FMIC) adds 50hp more I would say I got similar gains again - well circa 40hp...!! its also good to know that everytime I boot it my engine is getting a steam clean! I'll try to get on a dyno soon to compare map 2 with map 3 (dyno day anyone???).. I'll also do some logging and ask terry for a custom map 6 with meth integration - there is more to come! As ever big thanks to Neil@juiceduptuning for arranging the group buy and being a pleasure to deal with. Anyone who needs advice on this can send me a pm - cant promise to be an expert but will help out if I can... Last edited by phil200tdi; 03-03-2012 at 08:30 AM.. |
03-03-2012, 12:11 PM | #2 |
170
Rep 3,828
Drives: AzuriteBlack 335i E92
Nice write up!
This will something I will def look at. how was also going to go for the washer fluid install. Do you know roughly how long or how many pulls the 5l washer tank lasts? |
03-03-2012, 12:22 PM | #3 |
112
Rep 2,621
I need to work this out too. I've read conflicting reports of it pumping 100ml/min and 300ml/min... Probably somewhere in between.
Car: e91 330d with Viezu map
Gone but not forgotten: 2010 Jaguar XFR (Cat-back exhaust, pulley, intake mods and map), Highly Modified E90 335i LCI M Sport Manual (circa 480BHP/500lb ft) |
03-04-2012, 02:41 AM | #6 |
112
Rep 2,621
50:50 is fine on windows and very safe - non flammable. In the states some people just run low temp windscreen washer fluid which has 30-40% meth content...
People running 70:30 or higher concentrations are told to block off the windscreen washer jets as it may damage the paint.
03-04-2012, 02:51 AM | #7 | |
112
Rep 2,621
Washers work exactly as they did before.
03-04-2012, 03:26 PM | #8 |
14
Rep 454
03-05-2012, 05:09 AM | #10 | |
1545
Rep 8,970
I thought the BMS WW kit had a pickup hose you dunked in the washer bottle filler neck? Is that not how it works now? |
03-05-2012, 05:22 AM | #11 | |
112
Rep 2,621
I thought that too, but this way is much more stealthy! I think the pickup hose version is for the 135i??? I am going to buy some black flexible wiring conduit to make it all tidy and look almost OEM! This is similar to how mine looks currently except an N54 and with DCIs: |
03-05-2012, 05:28 AM | #12 |
1545
Rep 8,970
So the meth pump (obviously self priming) draws the fluid through the static washer pump rotor? (thus the need for a check valve before the washer nozzle)
Is there some kind of solenoid valve on the high pressure meth line, or is it controlled just by the pump on its own? Getting curious, love the DIY nature of this! |
03-05-2012, 06:03 AM | #13 |
112
Rep 2,621
Yes there is a solenoid valve which connects to the JB4 power wire and FSB, this is what allows progressive control of meth flow by the JB4. It is really rather clever!
Although I made the install sound complicated, it isnt really. The instructions could probably be a little better structured but are easy enough to follow... You can see the solenoid hanging from the pump in this photo oh and here is a teaser dyno graph showing Wheel Horse Power and Wheel Torque!!! |
03-05-2012, 08:42 AM | #15 |
76
Rep 1,518
Nice work phil
My RB turbos are arriving today and installation will be done next week and then I'll fit my meth kit Phil have you got an LSD?? You're definitely going to need one now!! |
03-05-2012, 08:52 AM | #16 | |
263
Rep 2,559
Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
03-05-2012, 08:58 AM | #17 | |
112
Rep 2,621
I can't wait to see the numbers you are pushing with RB turbos and meth.
03-05-2012, 09:06 AM | #18 | |
76
Rep 1,518
I'm getting them installed at Darren Wood in Manchester next Wednesday and will be picking it up on the Saturday. I was planning on going to the 'Ring later on in the year but in my e36 328i track car. Although I'm in two minds whether to keep that when it is finished or sell it and use the e92. Did you get the installation problem sorted? IIRC you had a water leak. |
03-05-2012, 09:09 AM | #19 | |
76
Rep 1,518
Cheers, can't wait myself |
03-05-2012, 09:21 AM | #20 | ||
263
Rep 2,559
I had two additional problems though: My mechanic forgot to reconnect the evaporative solenoid (see my thread in the US section) which gave me the 2A19 error code, and the vanos solenoids gave me a limp mode and so I had them replaced as well. Was all done today, so now the car should be ready to rumble. I'm currently testing a COBB stage 3 pump map, and a methanol map will also be made available to me within short. But right now it's snowing again, so I couldn't test or datalog anything anyway. Car feels great though, I'm sure you'll enjoy the upgrade! Alpina_B3_Lux P.S. Would be great if you came to one of the two 'Ring track days, in particular with your E92!
03-05-2012, 09:38 AM | #21 | |
76
Rep 1,518
Bad news about your error codes. I'm having my clutch, DMF, HPFP and water pump + thermostat changed at the same time as my car has passed 75k and I wouldn't want either of those issues crop up soon. As said, I can't wait to hear what you think of them, I know I will be happy with them. Rob has been fantastic and has given me many updates as I've been a bit unpatient due to an oil seal leak on my old turbos. I'm thinking of doing one trip first in the e36 and then if I can muster the courage, another one in the e92. I really want to visit Spa as well because it's one of my favourite tracks. Are you using Fuchs Pro Race 5w40 in your car? |
03-05-2012, 09:54 AM | #22 | |
263
Rep 2,559
And yes, I'm using Fuchs Titan Race Pro S 5W/40 now. I've also changed the diff and transmission oil, both with Fuchs oils. What clutch are you going for? I've installed the ClutchMasters FX300 and it seems fine so far, but I'm still in the break-in phase. For the RBs you will need something beefier than the stock clutch IMO. Alpina_B3_Lux P.S. @Phil: I hope you don't mind the slightly OT discussion...
