oil separator on 3 stage intake manifold
02-29-2012, 11:15 PM | #1 |
adrenergic stimulation
45
Rep 405
I bought a 3 stage intake manifold from an autorecycler and they told me it was off an X3. When I compared it to another members 3 stage mine does not have the round oil separator attached to it. My question is does my 325i single stage manifold have this separator attached to it already?
03-01-2012, 09:54 AM | #3 |
19
Rep 331
You got the correct 3-stage manifold. The oil separator is build into the motor already. Some of the manifolds like mine that came off a 530i show the oil separator on the manifold. There is really no way to remove it from the manifold so I had to modify mine to fit the 328i. If you have all the parts it's should be pug and play.
New - 2013 - 320i - 15% Tint - Future Mods ( BMS Tune, Suspension, Wheels, Exhaust)
Sold - 2007 328i (3-Stage Manifold - BMW Perf Intake w/Scoops - Powerbox - Magnaflow Exhaust - MMW Headers - KW Street Comfort - VMR 701s 19' w/M3 offset - BMW Strut Brace - 330I Brake Conversation - 5% Tint All Around - 8K HID Fog Lights -Angel Eyes) |
03-01-2012, 10:49 AM | #4 |
45
Rep 405
So let me see if I understand correctly. If the oil separator is built into my motor then I am all good. Some cars (ie 328) have the oil separator connected to the intake manifold and if you have a 3 stage without the separator attached to it you have to take it off the stock manifold and kind of rig it up in the engine bay? I want to make sure I have all the details down because I will be doing this in 2 weeks.
03-01-2012, 10:55 AM | #5 | ||
201
Rep 3,328
Drives: Coding: Desi4life10@gmail.com
The 325/330 have external oil seperators (that item pointed out in the picture). Therefore, those cars will have that seperator installed when they remove there stock manifold and can reuse it. The 328 don't use the external oil seperator and have it built into the upper crankcase. So basically you have a vent hose coming from the engine splitting into 2 to connect to the manifold. You CAN remove that external oil seperator from the manifold as it is held on by a few screws. I know this because I have already done this on my 328. But if you get a manifold from a 530 AFTER 10/2005 production date, you will be good to go with 2 vent house return ports on the manifold (Know from experience). Hope that clarifies the confusion. Quote:
Just reuse the seperator when you remove the old manifold from the car, it comes off. and attach it to your 3 stage manifold. Attaches via screws. Look in your engine bay and see what you have under the manifold. Item 1 |
03-01-2012, 11:20 AM | #6 |
45
Rep 405
Thanks a ton DESI, this makes more sense now. The 3 stage I bought has a mounting bracket where that oil separator goes so I can bolt it right on.
03-01-2012, 11:47 AM | #7 | |||
19
Rep 331
03-02-2012, 03:50 PM | #8 | |
64
Rep 954
2006 E90 325i | Sports Package | 6MT | 3IM | PE | AA |
