Spacers !! Info on Spacers
02-28-2012, 07:43 PM | #1 |
34
Rep 327
Hi was curious to see if anyone had any feedback on certain brands of spacers. Many people are saying "spacers are spacers" but I am pretty sure there are big differences on why some buy more expensive ones.. just wanted to know which spacers do you run? how do you like them? Also what are the bolts for? I may need a pair of 10mm spacers for the rear and want to hear out suggestions thank you!
02-28-2012, 08:30 PM | #4 | |
34
Rep 327
02-28-2012, 09:35 PM | #5 |
the mod bug is crawling in my brain
43
Rep 576
RS Techniks ftw! I'm very impressed with these spacers. Hit up Sean@pyspeed (vendor) he hooked it up with a good deal.
Also just a tip from my research but because of the length of the length of the hub lip, 10mm spacers don't sit properly w/o an adapter such as the one from turner Motorsport. If I were you I'd go 12mm and call it a day. |
02-28-2012, 10:56 PM | #7 |
15
Rep 101
I have H&R spacers and the fitment is flawless they clip snug over the hub centre and spacer machining & thickness is consistent.
you may pay dearly in the long run buying cheap spacers! also I would suggest a stud conversion as apposed to the stock lug nuts as this will make changing up wheels easier and some 75mm studs will let you play around with up to 10mm spacers. if you want to go bigger than 10mm spacers you will need 95mm studs! cheap spacers = poor machining & cheap aluminum which results in vibration through the wheel Hope this helps!!! and remember dont be shy hang 'em' out the guards with plenty of camber & post some pics!
02-28-2012, 11:12 PM | #8 |
Major nutz
86
Rep 1,488
Drives: '09 n54 e92xi, 6mt, kw v3
^+1 to 2jzbmw's comment. I have studs by Racing Brake and spacers from H & R, 10 and 12mm.
02-29-2012, 12:30 AM | #9 | |
34
Rep 327
02-29-2012, 04:36 PM | #10 |
METALCRAFTER
Rep 46
Drives: E92 335i
spacers are not just spacers because your mounting surface is not flat its has a slight radius to it so i wouldnt just buy any kinda of spacer! you could break your lug bolts this way!
03-01-2012, 08:37 PM | #11 | |
15
Rep 101
Good luck with it!
03-02-2012, 07:16 PM | #12 |
BimmerPost Supporting Vendor
2045
Rep 25,989
I think 12mm is a good size for any car. I just threw a pair of 12mm's on my car.
VMR|Wheels | 714.442.7916 |
03-02-2012, 09:14 PM | #13 | |
16
Rep 299
03-03-2012, 11:35 AM | #14 |
36
Rep 82
I run 12mm H&R spacers on the front to maintain the proper offset with my E46 ZCP wheels, and I speak highly of their quality. I also used 15mm Rogue spacers on my E36 track rat and they worked fine. Not as high quality as the H&R IMHO, but they did the job and in the end that's what matters.
Make sure you buy proper length lug bolts to match. Also, never, ever use 'two-piece' wheel spacers or wheel adapters. They are a terrible concept and failure-prone. -Evan
E92 335i/G20 330e
03-03-2012, 11:35 PM | #16 |
73
Rep 3,277
03-04-2012, 01:22 PM | #17 |
68
Rep 721
What size spacers would make my stock 17" wheels sit flush with H&R sport springs on my e92 335xi?
10-12mm rear? Extended lugs needed? How about the front? Same question about lugs? |
