Half opening window on unlocking car.
02-28-2012, 07:28 AM | #1 |
141
Rep 736
Hi all,
Can anybody confirm why the drivers window opens half way when sometimes unlocking my E92? It seems to happen in the garage quite a lot (where we have 2 cars parked (quite closely) next to one another). Is there a sensor which checks this and opens the window to allow for easier access? Thanks for confirming. Charlie |
02-28-2012, 07:31 AM | #2 |
1042
Rep 6,946
It is for easier access in a tight space, think its activated by holding the unlock button or pressing the window switch, not a sensor.
02-28-2012, 07:34 AM | #3 |
1397
Rep 8,083
press the unlock button twice and the window drops to allow easier access.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
02-28-2012, 07:43 AM | #4 | |
141
Rep 736
But I swear blind that I'm not and only the drivers window automatically drops half way. This made me think there might be a sensor. Just tried this and it opened, but the window didn't drop half way (the wife's car is not currently in the garage) |
02-28-2012, 07:54 AM | #5 |
Major Pain in the Arse
11
Rep 347
This happens to both my doors occasionally. I don't do anything differently unlocking the car.
I thought perhaps it was a calibrating mechanism or a response to the window being touched on opening the door, but it's not the latter. |
02-28-2012, 08:00 AM | #6 |
1397
Rep 8,083
It's definitely by pressing the unlock button twice to allow easy access. I know we're blokes but does nobody read the manuals anymore? You may not appreciate that you've pressed unlock twice but you have.
Ian
02-28-2012, 08:08 AM | #7 |
32
Rep 1,271
Drives: 335i (sadly gone)
I had absolutly no idea this happened. I have been just squeesing into the door in carparks! Maybe the manual should come out sometimes but imagine how boring it would be to read the whole thing to make sure you know everything.
02-28-2012, 09:06 AM | #8 | |
141
Rep 736
But good to know and thanks for the help. I will have to keep trying with this one. |
02-28-2012, 09:44 AM | #9 |
1397
Rep 8,083
I don't have my e92 anymore but the sequence that always seemed to work was to unlock - pause - unlock. The pause would be about 1s.
Ian
06-13-2013, 02:02 AM | #10 |
13347
Rep 7,484
Resurrection.
This happened to me yesterday. For the life of me I cannot recreate the sequence. I think I may have to read the manual. I do know that I pressed the unlock button twice or trunk release and then unlock - will have a play around with this again today. |
06-13-2013, 04:04 AM | #11 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
06-13-2013, 05:29 AM | #12 |
13347
Rep 7,484
I figured my issue out... I pressed trunk release once, unlock car once, waited a second and pressed unlock car again. As I opened the driver side door the window dropped two half way! Woohoo I recreated the sequence and glad I am not losing my mind...
Pressing unlock twice alone or with a pause between did not work for me... I have to press the trunk release and then unlock twice and it works everytime but only for driver side. |
06-10-2015, 04:52 AM | #16 |
45
Rep 441
I also got confused when this happened to me, I'd walk up to my car, unlock it, and if I was ever unsure that it'd unlocked I'd press it again and the windows would drop half way, but it took me ages to work out that the double press was causing it!
Handy for getting in if the space is tight though |
06-10-2015, 05:01 AM | #17 | |
283
Rep 2,343
Don't push unlock too often in case there's a self destruct sequence!
GC Turbos, FBO, JB4, DCT, Port Meth injection, BMS Charge Pipe, NGK plugs. EBC brakes and pads, LED Angel lights, LED foglights, LCI rears OCC, Braided brake lines. Custom Diff Lockdown Kit, VTT inlets, TMAP, stage 2+ fuel pump
11.79@119mph (stock turbos) 11.74@129mph (GC Turbos) |
06-10-2015, 12:10 PM | #18 |
400
Rep 5,623
Oh right, that would be handy then. Might give it a go but from memory it has never happened on my car.
06-12-2015, 05:06 AM | #19 | |
283
Rep 2,343
2, 3 or 4 clicks. In case the sensor fails to pick up one of the clicks...
06-13-2015, 10:09 AM | #20 |
Rep 30
Mate my car does the exact same thing and I don't press the button twice ive just added to the list
