MAF sensor
02-27-2012, 07:00 PM | #1 |
'The Godfather'
108
Rep 1,062
MAF sensor
Guys can anyone tell me where the air flow meter is situated on my 318d, im thinking that this may be causing my limp mode issue. Im going to try disconnecting it to see if the car runs any better.
Pictures would be great, thanks in advance Last edited by Brennan; 02-27-2012 at 08:10 PM.. |
02-28-2012, 02:40 AM | #2 |
1545
Rep 8,970
Not sure why it would work better without it, but its item 1 in the pic below:
http://www.realoem.com/bmw/showparts...29&hg=13&fg=20 Is you engine the N47? |
02-28-2012, 06:57 AM | #4 | |
886
Rep 9,097
It should improve your mpg, but I am strongly convinced that it is not responsible for your limp mode. As prior to your turbo failure, it was fine. Why would it become faulty now. Not sure about diesel but on petrol I had to take the air filter box out. It is fixed with torx screw. You can disconnect it though without taking it out if you have small and thin fingers. All the best.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
02-28-2012, 09:06 AM | #5 |
'The Godfather'
108
Rep 1,062
If its not the MAF then i really dont know what is causing the issue, theres only so many things it can be.
One thing i do know for a fact is that once i sell this car i'll never have another BMW after all this hassle. The engine in my car is the M47TU2D20 |
02-28-2012, 12:14 PM | #6 | |
886
Rep 9,097
I am not disappointing you, and go and clean it. After cleaning maf, run the car without it. You may get your car into limp mode though, so code resetter will be handy here. If you want little bit more experimentation and if you have digital meter, check the resistance of the maf, and double check with somebody here. Or with anybody who is near to you and allow you to check the resistance of his maf. It will give you idea, if your maf is normal?
