BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Clutch Delay Valve Removal
      02-21-2012, 10:03 PM   #1
rorkor
rorkor's Avatar
Drives: '11 E90 N52 6MT
2010 E70 X5 35d  [10.00]
2011 E90 328i  [10.00]
Anyone here running a 328i 6MT that has done the CDV removal. I am pretty handy but need to know if it is something I can do in the driveway or want to take down to the race shop on the weekend for.
I am having issues doing heel and toe with good results in my car. Never had the issue in the E36 M3 I used to drive.
      02-22-2012, 12:50 AM   #2
ladius
17
Drives: '06 bmw 330i
330i here with cdv removed. Had a shop do it because i had no idea but seemed simple enough, tech used a vice grip to clamp the clutch fluid line, removed the valve, hooked it back up, no need to bleed. Been 3 months, so far so good.
      02-22-2012, 01:43 AM   #3
kiwi29
Team iTouge
kiwi29's Avatar
121
Drives: 09 M-Tech 328i
From what I hear, its pretty easy if you have the tools to lift the carup and go under it. I don't have any of the correct tools needed so I'm going to ltbmw to do it hopefully or borrow a muffler shop's lift for 30 minutes. It seems easy enough if you're good with tools and know what you are doing?
Originally Posted by The HACK View Post
I'm going to use a very simple analogy, I hope you'll understand.
Driving is like having sex.
It really is. You can read up all you want about how to please a woman, you can look at all the diagrams in the world, but just like the clitoris, you won't know what the hell an apex is before you actually find it.
      02-22-2012, 02:55 AM   #4
SR2007
SR2007's Avatar
48
Drives: 07 E92 328i
I want to say there is a DIY on this. You should be able to reach it from the top on the engine bay if i remember correctly.
Amuse Trunk/Amuse Front/CF M3 Hood/Hamman Spoiler/Staggered Iconz/Custom Interior/MMW Headers/Straight Pipe/Custom Tune/330 Mani/too much too list.....
Team Elite / WFC#342
      02-22-2012, 09:31 AM   #5
ZZZZ
50
Drives: Z4 3.0i winterbeater
It's pretty easy to do yourself, if you're handy with your tools. Don't really notice much difference on the e90 though. e36 and e46 were much different with CDV removed compared to this. But whatever, it didn't cost anything to do.
      02-22-2012, 02:58 PM   #6
bimmer848
Drives: 2006 325i
it literally took about 4 minutes when the car was in the air. i had a rack to use so it made life easy, but mods do not get any easier than this. i felt a huge difference in my e90 so i guess it depends on each person, but before cdv removal, short shift arm and new lever bearing, i was close to getting rid of this car! now it feels like a proper gear box. do it!
-Cheers
      02-22-2012, 08:01 PM   #7
rorkor
rorkor's Avatar
Thanks, looks like something I will get to next weekend!
      02-28-2012, 12:34 PM   #8
kiwi29
Team iTouge
kiwi29's Avatar
121
when you do, please post a DIY since there's only one from an e46 :/
      02-29-2012, 01:05 PM   #9
Helka
Helka's Avatar
Drives: 328i
I just the cdv delete on my 328i and i dont know why i held off for so long. amazing feeling being able to shift from 1-2 without giving your passenger a whiplash
One word of advice. When bleeding the clutch (highly recomended) make sure you top up the brake fluid above MAX and after a few pumps and releases of the clutch top it up again. The clutch resevoir in the brake canister has a spill over partition so if you just look at the main brake fluid and see that it is topped up, the clutch side is propably nearly empty.
I did a reverse bleed using a brand new oil can and pumped the fluid from the slave cylinder to the brake fluid canister. That will get all the air out almost 100% over pumping the clutch pedal since bubbles naturally want to travel up.
A must do mod on our cars!
2007 328i
BMS PBX---M3 Short Shifter---Muffler Delete---CDV Delete---Eibach Prokit---Injen Intake---M6 reps---M3 Lip Spoiler
      02-29-2012, 05:09 PM   #10
Crusader
15
Drives: E92 M-sport
CDV delete
My E39's made a smooth 1-2 shift impossible with the CDV. I quickly removed them. Not so with the E92, though I don't rush the synchros, so I may not remove it. The delete is incredibly simple, just be sure and use the proper tools, cap off the fluid line, and to be meticulous ... bleed the slave cylinder.
If you're concerned about your warranty, you can replace the CDV with one that has its guts removed (this is a much more valid concern in terms of warranty maintenance than the "only service with BMW approved oil" worry ... clutches DO fail, engines almost never fail if the oil level is maintained). In this case, bleeding the system is a must.
      02-29-2012, 09:58 PM   #11
bbbuzzy
18
Drives: '13 335is convertible (manual)
I agree with all the posters that it's a must do mod. I also can't believe I waited years before doing it. Made a huge difference. I had an indy shop do it while I was in for other maintenance. They bled the line after installing the modified CDV from Zeckhausen.
'11 X3 xdrive35i
'15 Sienna Limited AWD (road tripper)
'06 330i MT, sport,premium (retired)
